First post, by Shagittarius
- Oldbie
I'm running 2 different XP machines both using WinXPSP3 with all the most recent official updates. The machines are different in many ways however I believe the most important way that they differ for this question are in video card drivers. One machine Is running an Nvidia ti4200 and the other machine is running a 780ti both through DVI output to my ASUS VS228 monitor. The ti4200 passes 640x480 to the monitor and the aspect ratio is correct at 4:3 while the 780ti will stretch the image to 16:9. I'm sure this must be down to driver versions, is there anything I can do to correct the aspect ratio of that resolution on the 780ti?
Oh also if I set the refresh rate to 75hz then the 780ti also correctly passes the 4:3 aspect ratio but this doesn't help me with games that force 640x480 in 60Hz.
