First post, by buckeye
Been looking at various LCD's to replace my 19" Acer model which is ok for windows games but terrible for dos.
This Samsung Syncmaster 932bw specs at 1440 x 900 75hz. TFT, would this possibly work better for DOS games?
Reply 1 of 2, by darry
buckeye wrote on 2021-01-05, 14:56:
Hard to say from looking at the manual.
3 points to consider :
- Can it display square pixel modes like 640x480 in 4:3 aspect ratio ?
- Can it display non square pixel modes like 320x200 in 4:3 aspect ratio ?
- What does do monitor actual do with >60Hz input (like 70Hz)? Does it actually display it as such or does it skip frames to bring it down to 70Hz .
If you already have the monitor, try it and let us know . Otherwise, if I were you, I would not chance it.
My suggestion is that you read or at least skim through this Widescreen monitors and 4:3 aspect ratio compatibility thread
I know it is 15 pages long, but it would give you some perspective on what to look for, IMHO . To make it shorter, skip to posts from 2019 onward .
TLDR: If cost is not an issue, an OSSC combined with a monitor that can handle 70Hz in and out (modern freesync capable ones should work fine) and has an explicit 4:3 mode is the best current LCD based solution for DOS games, IMHO .
Reply 2 of 2, by shamino
I assume that's a common/cheap TN panel, so it shouldn't have any problem with 70Hz. IPS/VA panels will have issues with that (they have a narrow range from about 56-64Hz, so their advertised "75Hz" relies on stutter), but I think any TN panel will do up to 75Hz natively without any stutter issue as long as you use the VGA input.
I have a Samsung 943SWX which is 1360x768. That one at least does have an option to display 4:3 properly with black bars on the side. I think that was a common feature on early widescreen Samsungs.
I think it also has an option to display 1:1. No option for integer scaling though.
Again I'm talking about the 943SWX, I haven't used the 932BW but just guessing it would have similar features.
Samsung monitors in that period frequently die from bad capacitors. They're easier to replace than on a motherboard.
