Windows 95 Dos window video problem
Discussion about old graphics cards, monitors and video related things.
Re: Windows 95 Dos window video problem
Postby shaq » 2017-1-03 @ 19:41
chinny22 wrote:Maybe this is of help? not sure which Voodoo you actually have!
https://www.vogons.org/viewtopic.php?f=46&t=35721
Also maybe try a different windows driver. I like the reference or the fastvoodoo drivers depending on which system I'm using
I'm using the Voodoo 1(Diamond Monster 3D) so that list doesn't help unfortunately. Does driver cleaner pro do an adequate job removing the old driver? And where can you find different drivers? I only see the latest ones out there, reference and tweaked. ANd I had a similar problem with voodoo1 and 2. But this Voodoo 1 is worse, I'm even having trouble exiting windows glide games. I get a black screen and windows locks up and I have to reboot. So I definitely need to find new drivers.
shaq
Postby Jorpho » 2017-1-03 @ 19:51
If you're running a DOS game, I would not expect the Windows drivers for the Voodoo card to make any difference.
User avatar
Jorpho
Postby chinny22 » 2017-1-05 @ 13:16
Jorpho wrote:If you're running a DOS game, I would not expect the Windows drivers for the Voodoo card to make any difference.
Me either really, but as the game works fine in DOS, its at least something to try
shaq wrote:I'm using the Voodoo 1(Diamond Monster 3D) so that list doesn't help unfortunately. Does driver cleaner pro do an adequate job removing the old driver? And where can you find different drivers? I only see the latest ones out there, reference and tweaked. ANd I had a similar problem with voodoo1 and 2. But this Voodoo 1 is worse, I'm even having trouble exiting windows glide games. I get a black screen and windows locks up and I have to reboot. So I definitely need to find new drivers.
You could try the drivers from here
http://www.3dfxzone.it/dir/3dfx/voodoo1 ... /windows98
Cant recommend any though I've only got a V2 which is what the fastvoodoo driver is for.
That same post talks a lot about how DOS games actually support glide, like this particular post.
https://www.vogons.org/viewtopic.php?f= ... 20#p307605
I would have thought if DOS glide games didn't work form 9x it would have come up by now, and the EF2000 V2 patch even requires windows, it MUST be possible somehow. I think were the ones missing something. I'll try and "find" and test a game on my V2 setup, but that wont be for a few weeks am afraid
User avatar
chinny22
Previous
Return to Video
Who is online
Users browsing this forum: Vynix, xjas and 7 guests
