Reply 1 of 10, by Sphere478
- l33t++
Reply 2 of 10, by Kahenraz
- l33t
It would still collide with the little arm that holds it in place.
Reply 3 of 10, by Joseph_Joestar
- l33t
I've had a similar experience when trying to use later PCIe GPUs (2009 and onward) in some early PCIe motherboards.
They are simply too long to physically fit, bumping into motherboard capacitors, heat sinks, battery holders, you name it.
Reply 4 of 10, by The Serpent Rider
- l33t++
Isolate battery edges and arm. Done. Or you can't install the card into slot properly?
Reply 5 of 10, by Kahenraz
- l33t
It's not fully inserted. At best, I could replace the surface mount polymer capacitors with a through-hole version with some extra length and tilt it out of the way. But I'm not keen on modifying this card and it's the first one out of several that I've bought so far that actually works.
Reply 6 of 10, by The Serpent Rider
- l33t++
Easiest solution would to change motherboard ¯\_(ツ)_/¯
Reply 7 of 10, by Grem Five
- Member
Kahenraz wrote on 2022-04-23, 08:59:But I'm not keen on modifying this card and it's the first one out of several that I've bought so far that actually works.
Remote mount the battery
Reply 8 of 10, by Kahenraz
- l33t
That's what I settled on as the best option, if I want to use this particular motherboard.
Reply 9 of 10, by Tetrium
- l33t++
That's really unfortunate 😒
The Serpent Rider wrote on 2022-04-23, 10:13:Easiest solution would to change motherboard ¯\_(ツ)_/¯
or change the graphics card 😋
Reply 10 of 10, by The Serpent Rider
- l33t++
Well, yeah, you can always install GeForce FX 5900XT. Although motherboard deserves an axe anyway.
