First post, by bobconan
I have a Trident 8900D with the TKD 8001 DAC. Id there a way to know if I have the 16 bit or the 24 bit version?
Thanks
Reply 1 of 4, by kixs
Get PCPBENCH for DOS and run it as:
PCPBENCH /MODES
It will list supported VESA modes. Then you can test the modes with:
PCPBENCH XXX (XXX being the VESA mode number listed before)
Reply 2 of 4, by Grzyb
According to the datasheet I found, TKD8001 supports up to 24-bpp.
Are there TKD8001 variants limited to 16-bpp ?
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
Reply 3 of 4, by Gmlb256
kixs wrote on 2023-10-25, 17:15:
Get PCPBENCH for DOS and run it as: […]
PCPBENCH /MODES
PC Player Benchmark doesn't list nor support the 24bpp VESA video modes. I would suggest using VESACHK instead for that purpose and run it like this:
VESACHK | more
In the list, BP is bits per pixel.
