First post, by bobconan
I have a Trident 8900D with the TKD 8001 DAC. Id there a way to know if I have the 16 bit or the 24 bit version?
Thanks
Thanks
Get PCPBENCH for DOS and run it as:
PCPBENCH /MODES
It will list supported VESA modes. Then you can test the modes with:
PCPBENCH XXX (XXX being the VESA mode number listed before)
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
According to the datasheet I found, TKD8001 supports up to 24-bpp.
Are there TKD8001 variants limited to 16-bpp ?
Nie rzucim ziemi, skąd nasz root!
kixs wrote on 2023-10-25, 17:15:Get PCPBENCH for DOS and run it as: […]
PCPBENCH /MODES
PC Player Benchmark doesn't list nor support the 24bpp VESA video modes. I would suggest using VESACHK instead for that purpose and run it like this:
VESACHK | more
In the list, BP is bits per pixel.
I see. You can also run DRHARD and see all the VESA modes - under Devices > Graphics adapter > VESA
