First post, by aljares
Hello
I want to instal a dos 6.22 on a CF ( 512 mg) over a laptop 386 sx 4 ram and CF ide adapter. floppy dont work
to install dos on a CF , i try on a qemu with fisical acces to CF.
I try to install with floppy images
try 1
normal install , stop on formating can format invaleid format
try 2
delete partition , fidsk create dos primary partition and actived
formact C: formating compled but not boot write
try 3
on a image qemu file work fine and i can isntall easy, may be install on a file and then xcopy to CF , but i can fin copy nothing to the Cf error , retry or fail
CF it is on fat 16
any ideas or trys ? it is my frist time
any help , guides or some will be apreciated
i can not instal fro origina lmachine because floppy dont work
Reply 1 of 7, by xjas
For the second method, try running:
fdisk /mbr
then create the primary partition with fdisk
format c: /s
sys c:
You'd think those would do the same thing, but I've occasionally found I need to run SYS C: anyway, even though Format /s should transfer the system files. Also make sure the 'boot' flag is set on the primary DOS partition.
selected builds & megathreads { Quick & Clean | Like a Hipster | Only One 'T' | In a Lunchbox | IT IS THE NINETIES }
Reply 2 of 7, by Jo22
aljares wrote:
try 3
Hi there! #3 isn't bad IMHO.
a) run win32diskimager and image your real cf card
b) use that image in qemu ande install DOS
c) write that image back using win32diskimager
d) install cf card in your laptop.
Reply 3 of 7, by aljares
ok i can install msdos on CF.. but another problem
i put CF on a id CF adapter and .... the bios of the i386 can recognazie the HD , the 0-46 hd can not work and user defined 47 i dont know to configure
any help
Reply 4 of 7, by GigAHerZ
CF accepts pretty much every setting you throw at it. So you can just manually type some almost random numbers in, just don't go over the real size of the CF card.
Also, if you want exact settings for 512MB CF card, the internet is full of this information.
Reply 7 of 7, by Jo22
aljares wrote:
OK, solved i put the information i obtain with ranish partition from qemu , but not boot in real hardware
Hi again, my I ask what kind of BIOS is your old computer running ? Award, AMI or Phoenix ?
- If you're lucky, PCem/86Box emulate a machine configuration with the same BIOS.
Using the same BIOS type increases the chances that your HDD image is also bootable on the real thing.
MAZter wrote:
Aljares, why don’t you want to replace the FDD first? Which fdd model?
Good point. I for one had several issues in the past duplicating BIOS settings on emulators.
That's why I often tried to make an old computer's floppy drive working first - partially, at least (say with a custom DOS floppy formatted to 360KB or 720KB).
Edit: Small edits.
