Reply 20 of 35, by filipetolhuizen
- Oldbie
Is your directx up-to-date? Remember to disable Win98/Me Compat. mode for the game exe before running if you enabled it.
the directX is up to date and the campatibility mode is disabled
Have you disabled Mipmap filtering in the options already?
where can i disable them?
I cant find it in options.txt
In the startup options. With my fix the window is not crippled anymore, so you can disable it under the video options.
Is it in the compatibility mode options? (I dont know because I have the german windows)
well I disablet something that could be that and now it loads untel 2 thirds of the loading bar instead of one quarter.
But stilll the directX error
Edit: Now again by one quarter
It's in the game's options startup menu.
Can you explain me where in the options? I dont know mipmap filters in german so I dont know what I have to search for
This is the option menu. You just have to disable Mip Filter.
well now I know which menu you mean
the problem is I dont know how to enter it
the first times I started the game it opened itself but now it doesnt anymore
I dont know why
Isn't there a Setup shortcut on the game's startup folder? If not, just run tdr2000 -s.
ther is no setup.exe and if i start tdr2000 It starts the game without showing that menu
There is no setup.exe. You run tdr2000 -s to start the setup.
How do I do this?
You can edit the shortcut to the game on the start menu and add the -s in the of the command line.
It works now!
Thank you very much
