First post, by theRobin
Hi, first post here from a long time lurker.
Apologies if a thread exists for this problem but I never have much luck with the search functionality on this site.
Anyway I've built myself a Windows 98 SE box (and a 486, AND a Pentium 200...) to re-live some happy times past, but I think I'm having trouble with the 3D video performance:
ep-3vca MB with the latest bios
1Ghz Pentium 3
512mb RAM
400w PSU
Winfast Geforce2 GTS 64mb
It all runs fine, System Shock 2 for example runs very well, but it lags in Dues Ex 1, and based on the system requirements for that game it should not.
And the other thing which makes me suspicious is that it lags the same amount whether I use a 640 resolution or a 1024 resolution, textures high / low, etc.
I’ve installed the most recent VIA 4in1 drivers, tried the latest nVidea drivers and the latest Winfast drivers (which installs a gart driver too), but no improvement.
I tried using a slower Geforce2 MX 64mb and the performance is the same, which makes me more suspicious that something isn’t right.
And I’ve messed around with the settings in the BIOS RE the AGP, aperture size, etc. All I’ve managed to achieve there getting stuck in 2x mode as apposed to 4x (which the motherboard supports and which I’ve seen working).
Anyway my only remaining thought is to re-install Windows 98 SE. Does anyone here have any ideas?
It couldn’t be the processor bottlenecking me, could it?
Thanks for any help.
Reply 1 of 28, by RogueTrip2012
Sounds like your above the curve on specs.
Are you using Via 4.43 drivers?
Also try a 4x.xx nvidia driver as I heard they were some of the best. Not saying these are the best but in my nvidia videocard folder I have 44.03 and 45.23 listed and probably found those recommended from another forum.
Via chipsets had issues using AGP4x hence the AGP 2x mode. You can use Rivatuner to try an enable 4x but not worth the effort as test show 4x not show any real improvement.
make sure all drivers are cleaned out when uninstalling. I use DriverCleaner 2 when possible after an uninstall. search for DC2Setup_27.
Reply 2 of 28, by Davros
try using the enhanced opengl renderer for deus ex
Version 2.0 for Deus Ex (works with Deus Ex version 1112fm): dxglr20.zip (110 KB).
http://www.cwdohnal.com/utglr/
Reply 3 of 28, by Tetrium
I had a Winfast GF2 that developed a leaking cap once. Check if yours is also the one with a single cap (even though you already mentioned the GF2MX has the same performance).
And welcome aboard! 😉
You should post topics of all your rigs! 😁
Where could I find these?
My retro rigs (old topic)
Report spammers here!
Reply 4 of 28, by RogueTrip2012
Agreed
Where could I find these?[/quote]
ftp://download.nvidia.com/Windows/
Reply 5 of 28, by swaaye
Deus Ex will probably run best through Glide on old hardware. However I do think the game is fairly demanding. My EeePC with GMA 900 and Celeron M 900 that runs JK2 great runs DX poorly.
A 1GHz P3 isn't far off the mark for the time but that doesn't mean it's ideal. UE1 is very CPU intensive due to design issues (hence sad polycount) and DX has some relatively large and complex maps.
Reply 6 of 28, by Tetrium
Thanks! Odd these downloads were listed only 2 days ago?
Reply 7 of 28, by Davros
from the readme of patch 1.112f
"If you are experiencing slow Direct3D performance, you may want to try using OpenGL as your rendering device. OpenGL in Deus Ex is unsupported, but has shown significant performance gains under certain circumstances (particularly on Nvidia chipsets such as the GeForce)"
ps:
System Requirements
Minimum Specifications: 300 Mhz Pentium II or equivalent
Windows 95/98
64 MB RAM
DirectX 7.0a compliant 3D accelerated video card
DirectX 7.0a compliant sound card
DirectX 7.0a or higher (included)
4X CD-ROM Drive
150 MB uncompressed hard drive space
Keyboard and Mouse
Recommended Specifications:
AMD Athlon or Intel Pentium III processor
128 MB RAM
3D accelerator with 16 MB VRAM
8X CD-ROM Drive
750 MB uncompressed hard drive space
EAX or A3D compliant audio card
Reply 8 of 28, by theRobin
Thanks so much for the responses guys, I'll give your suggestions a try and let you know how it goes.
I will post some pics of my rigs when I get a moment; I can't tell you how exciting it is that someone else is interested in them. My wife has nothing but contempt for my beautiful beige boxes - I caught her resting a drink on one the other day?! Outrageous.
Reply 10 of 28, by Tetrium
Those Vortexes 'sound' like trouble, judging from reading user experiences here.
Reply 11 of 28, by theRobin
OK I've invalidated my test results a bit because a Geforce2 Ultra I'd ordered has shown up in the mean time and I've replaced the GTS with it, but:
- clean install of Win98 SE
- 4.43 VIA drivers (I was already using those)
- ver. 45.23 of the nVidia drivers
The geforce is reported as 4x AGP now (a symbolic victory I know but I get a bee in my bonnet about such things) and the performance is much more like I'd hoped it would be.
Deus Ex still lags a bit a higher resolutions & 32bit but at now I can turn the resolution down a see a performance improvement, instead of poor performance across the board. So it was definitely a driver issue, I think.
That's all in DirectX too BTW, I'll try the enhanced opengl renderer at some stage too.
Well that's my PIII pretty much finished now, I guess it's time to sit down and use it... or maybe I need a P4...
Thank you all for your input.
Reply 12 of 28, by Tetrium
We want pics! We want pics! 😜 😜 😜
You'll only need a P4 (or Athlon XP) if you want to play more demanding games btw. Many of us Vogoners have more then 1 rig to better suit their needs 😉
Reply 13 of 28, by F2bnp
Deus Ex is not THAT demanding. A 1GHz Pentium 3 should be more than enough for it.
The Via AGP is to blame here, if I were you I'd go for even older drivers. Last time I tried, I found that drivers released close to the time frame of the motherboard generally worked best.
Reply 14 of 28, by sgt76
The 1ghz P3 + GF2 should burn through that game. I do share your view that earlier drivers would work better- I've had the best results from driver ver 2x.xx using Win98SE/ VIA Apollo Pro/ GF 256/2/3/4 / PIII combos.
Reply 15 of 28, by swaaye
Burn through as in 20fps? 😀
http://books.google.com/books?id=5gEAAAAAMBAJ … %201ghz&f=false
http://groups.google.com/group/comp.sys.ibm.p … s+ex+1ghz&pli=1
But there is no doubt that VIA AGP affects performance. The VIA memory controller just might as well.
Reply 16 of 28, by sliderider
swaaye wrote:
Burn through as in 20fps? :) http://books.google.com/books?id=5gEAAAAAMBAJ … %201ghz&f=false http://groups.google.com/group/c […]
It looks like Deus was the Crysis of it's day, bringing even brand new, fast systems to their knees.
Not running the game with all the bells and whistles turned on should help. That's probably the biggest reason why the older, slower Voodoo 5 ran it faster than the GF2 GTS. 32-bit color gave a big performance hit using the video cards of those days. Lowering the settings or using a newer video card that doesn't take such a big hit with 32-bit color turned on should plow through that game.
Reply 18 of 28, by sgt76
Egads! Reading a bit looks like this game has some massive problems with D3D implementation.
I should do some testing of my own- I have the game though it's a relatively recent addition to my collection and as yet I haven't found the time to play it- and all the required hardware- P3 1ghz, various VIA s370 boards and old GF cards.
Reply 19 of 28, by sliderider
That appears to be the case
http://pc.ign.com/articles/081/081880p1.html
Apparently there's a patch floating around out there that improves D3D performance. The link in the article is dead now, though, so anyone needing it is going to have to hunt for it.
