First post, by sliderider
- l33t++
After you boot it go to Options and set Bump Mapping to low if you are experiencing the crash to desktop bug. I don't know if this is a software or hardware bug but it is the only way that I have found to correct this issue. What usually happens if it is set to anything else is when you try to start the game it will hang for a couple of seconds and then exit. Setting BM to low allows the game to start normally.
