First post, by sliderider
After you boot it go to Options and set Bump Mapping to low if you are experiencing the crash to desktop bug. I don't know if this is a software or hardware bug but it is the only way that I have found to correct this issue. What usually happens if it is set to anything else is when you try to start the game it will hang for a couple of seconds and then exit. Setting BM to low allows the game to start normally.
Reply 1 of 7, by leileilol
This bug starts to occur in Radeon HD and up, doesn't occur on X600-800 or X1x00 at least
Reply 2 of 7, by sliderider
Did ATi change how bump mapping is handled with the HD cards or did they remove it in favor of tessalation? Or is bump mapping and tessalation the same thing?
Reply 3 of 7, by leileilol
PS 1.4 regression
Reply 5 of 7, by sliderider
leileilol wrote:
PS 1.4 regression
What does that mean?
Reply 7 of 7, by Davros
That explains pixel shaders not pixel shader 1.4 regression
ps: afaik, the unreal engine used by republic commando didnt support bumpmapping, it was a hack done by nvidia that was very buggy (could be wrong though)
