indirect sound
Reply 160 of 160, by KainXVIII
lowenz wrote:
There is :) […]
There is 😀
https://www.indirectsound.com/downloads.html
Version 0.20 — 2019-09-21
Changes since the previous version:
Fix how Doppler Factor is used
This fixes the bad engine revving sounds in Drome Racers
This also correctly constrains the amount of frequency change that can happen as a result of Doppler calculations
Fix buffer description copies for old versions of DirectSound
IndirectSound had assumed that buffer descriptions were always the same size as DirectSound 7 or later
Ah, thanks!
