First post, by Bruninho
I have managed to build a Win2k VM under Qemu, but using the UTM app for iOS (a Qemu wrapper).
I currently have only one issue: An unknown device is listed under device manager. System Information reports ACPI\QEMU0002 and ACPI\PNP0103 as unknown devices. Since I do not know which devices they are - I cannot identify them - therefore I cannot find drivers for these. Anyone know how can I fix this? They seem to be related to ACPI.
ACPI is defined as ACPI Multiprocessor PC, but if I switch to Standard PC or something else, I lose the USB.
I was bfcastello, now I am Bruninho! =]
JOBS, Steve.
Reply 1 of 17, by DosFreak
For QEMU0002 you can try the guest drivers, unknown if they work in Windows 2000: https://github.com/virtio-win/kvm-guest-drive … indows/releases
For PNP0103 that's HPET and isn't supported in Windows 2000. Should be disabled in the BIOS if can't be used.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 17, by Bruninho
DosFreak wrote on 2020-03-23, 22:00:
I somehow fixed the issue turning off the ACPI on Device Manager. The unknown device disappeared - I just switched from ACPI Multiprocessor PC to Standard PC. All OK now, and proceeding to updates & installing kernel extender, apps....
JOBS, Steve.
Reply 3 of 17, by Bruninho
Something probably wasn't properly installed in my Win2k QEMU. I cannot update the Windows Update Agent with the WUA installer (reports unrecoverable error and complains about the lack of MSVCRT90.dll) and I cannot install last supported WinZip version too.
While on VMWare I  can still access Windows Update and run WinZip.
I've lost almost two days trying to debug the problem.
JOBS, Steve.
Reply 4 of 17, by DosFreak
If you've already installed the Blackwingcat software there is no reason to use Windows Update since you should have updated Windows before that.
Use 7-Zip.
Reply 5 of 17, by Bruninho
I just added riched20.dll and msvcr90.dll from another win2k install I had working, and installed net framework 2.0 & vc++ 2008. Then I could install WUA 3.0 and access the windows update. Hooray. I will update and then try again WinZip. I have WinZip working in another Win2k install. I just have to remember what the hell I did to manage this.
JOBS, Steve.
Reply 7 of 17, by Bruninho
Yup. After I proceeded to update everything and install a great browser, turns out that Youtube is damn, damn slow. The browser is even slower under QEMU. I threw it straight to the bin, and decided to stick with the only Win2k VM I have perfectly working here - The VMWare Fusion one. A lost weekend, but oh well. That's how the things are.
JOBS, Steve.
Reply 8 of 17, by Bruninho
Reinstalled UTM app on my iPad, and instead of Windows 2000 (laggy), I used a copy of my Windows 3.11 VMware machine. Remember, UTM is a QEMU wrapper for iOS.
Imagine my happiness and surprise when I saw that it worked and I can connect to google.com with IE5.0 and use mIRC (even joined #VOGONS channel) all from my iPad Pro. Previously, I needed to use an script with a rPi3 in the middle to have internet connection (and that with a DOSBox iOS wrapper, named DOSPad/iDOS2, from litchie).
Well, turns out I do not need anymore, as this QEMU variant on iOS does it well. I’m quite surprised. UTM is still far from ready (its still beta) but for things like this, its reliable.
I wonder if it can run well on Windows 98. Probably not, since Win 2k was quite laggy.
JOBS, Steve.
Reply 10 of 17, by Bruninho
robertmo wrote on 2020-04-01, 07:07:
didn't know we have a #vogons irc channel 😉
unless you mean the efnet one 😉
i think its on ircslashdot.org, since stiletto is there (probably a bot, since he does not reply, hahaha)
JOBS, Steve.
Reply 11 of 17, by Bruninho
I'm now with a strange problem, one of my games... "where in the world is carmen sandiego?" the colored one, with better graphics.
th?id=OIP.j8DT2yYvW0FcJoKkZ4KvWgHaEp&pid=Api&rs=1
Works on DOSBox and the UTM machine, but now it does not work anymore for some reason on my VMWare machine? It crashes the VM when it gets to the ACME machine greeting me (before it even asks for my detective name). I dont know why since I havent changed the VM settings.
JOBS, Steve.
Reply 12 of 17, by Bruninho
I just had a nightmare last 24h attempting to free more ram for MicroProse's F1 Grand Prix (1991), after several errors and incredible mistakes from my part (I can't even describe them since I am ashamed of them) I managed to make my VM run the game. Now there's only the Carmen Sandiego's game to fix - I dont know why it crashes on me when using the VMware and Qemu versions, but when using the DOSBox version it runs... freaking strange!
Now that the F1GP game runs on VMware version, let's copy some settings to the Qemu version on my iPad Pro.
Also, another difference is that I can run Windows 3.x in enhanced 386 mode with DOSBox, but not VMWare and Qemu.... I dont know why!
JOBS, Steve.
Reply 13 of 17, by DosFreak
Virtualization is bad for compatibility but good for speed. Also it helps that DOSBox development is focused on games whereas Vmware and Qemu are not.
Reply 14 of 17, by Stiletto
Bruninho wrote on 2020-04-01, 08:40:
I'd forgotten there was an EFNet channel. [EDIT] apparently there wasn't until today? I'm confused now...
Not a bot! But for a while there I was on an opposite schedule to the others in Europe who had been popping in.
do the Fandango!" - Queen
Stiletto
Reply 15 of 17, by Bruninho
Apparently carmen sandiego's game has an issue with the sound. The log from vmware fusion has some lines about the sound before the VM gets shut down when running the game. Strange. Well, theres a VMWare Fusion update apparently, lets see...
EDIT: For now I just keep an older version of the game (the first black-and-white graphics version...) running, that's enough. It's almost pretty much the same gameplay anyway, minus the dossiers for each villain. I can play the newer version on other VMs.
JOBS, Steve.
Reply 16 of 17, by Bruninho
Stiletto wrote on 2020-04-02, 00:58:
I just came back to see. Yup, there is on slashdot server.
The VM on UTM/iPad Pro is rocking. Definitely a lot more stable than DOSPad/iDOS 2 and has networking. I feel tempted to do a Windows 98 VM now, even without a proper browser for that (well, Retrozilla/Netscape 9 is almost right for the job).
JOBS, Steve.
Reply 17 of 17, by Bruninho
I am currently tweaking my autoexec and config files. Anyone know how can I set it up to accept some brazilian portuguese accentuation when using the editor or command prompt, with an US international keyboard? It’s MSDOS 6.22, english language, and I want to keep it in english but accepting some brazilian portuguese accentuation...
While on Windows 3.11 it works as intended. English language, I can type brazilian portuguese on Notepad...
JOBS, Steve.
