First post, by Cauterize
- Newbie
Hey Vogons,
I stumbled upon quite a few threads regarding compactflash cards being used in place of old IDE hard drives here, however, I couldn't find any definitive guides on getting them set up correctly.
As of recent I have bought a 4GB compact flash card and a 40-pin IDE to CF adapter ready for use. I have an Amstrad Mega PC 386 ready to get these in, but I want to make sure I am doing it correctly.
Please could someone advise on the correct steps to setting this up and getting DOS & Windows installed on this system correctly?
The steps I am most curious about are:
1) What jumper settings do I require on the IDE 40-pin to CF adapter? Master?
2) How to correctly format and partition the compactflash card - (I read somewhere that partitions cannot be larger than 512mb, is this true?)
3) Which software would I use to do this? Can I do it on my (modern) laptop running Windows 7 or must it be set up on the original hardware?
4) I saw something mentioned about compactflash cards needing to be changed to 'Fixed Disks' - is this necessary and how do I go about changing this?
5) Are there any special BIOS settings I will require? There were some in there I noticed regarding hard drives, however, I have no idea what they should be for a standard hard drive, nevermind a compactflash card!
6) Once partitioned and working in the Mega PC, will I be able to take this compactflash card out and plug it into a CF adapter on my (modern) laptop? I'd love to know if possible as it would make it much easier installing software rather than writing to floppy disks each time.
7) Any other suggestions? 😀
Thank you so much for taking the time to read, and hopefully reply!
Adam
