First post, by Cauterize
Hey Vogons,
I stumbled upon quite a few threads regarding compactflash cards being used in place of old IDE hard drives here, however, I couldn't find any definitive guides on getting them set up correctly.
As of recent I have bought a 4GB compact flash card and a 40-pin IDE to CF adapter ready for use. I have an Amstrad Mega PC 386 ready to get these in, but I want to make sure I am doing it correctly.
Please could someone advise on the correct steps to setting this up and getting DOS & Windows installed on this system correctly?
The steps I am most curious about are:
1) What jumper settings do I require on the IDE 40-pin to CF adapter? Master?
2) How to correctly format and partition the compactflash card - (I read somewhere that partitions cannot be larger than 512mb, is this true?)
3) Which software would I use to do this? Can I do it on my (modern) laptop running Windows 7 or must it be set up on the original hardware?
4) I saw something mentioned about compactflash cards needing to be changed to 'Fixed Disks' - is this necessary and how do I go about changing this?
5) Are there any special BIOS settings I will require? There were some in there I noticed regarding hard drives, however, I have no idea what they should be for a standard hard drive, nevermind a compactflash card!
6) Once partitioned and working in the Mega PC, will I be able to take this compactflash card out and plug it into a CF adapter on my (modern) laptop? I'd love to know if possible as it would make it much easier installing software rather than writing to floppy disks each time.
7) Any other suggestions? 😀
Thank you so much for taking the time to read, and hopefully reply!
Adam
Reply 1 of 8, by 5u3
No, it's the size of the whole disk that can't exceed 504 MiB / 528 MB. This is a BIOS limitation typical for PCs from before ~1994.
There are ways around the limitation, but if you don't have much experience, I'd rather recommend getting a smaller CF card (up to 512 MB).
Reply 2 of 8, by Davros
look at this vid
http://www.youtube.com/watch?v=KLuykrAIkfc
he had to add the heads and cylinders in the bios I dont know how you'd do that for a compact flash
Reply 3 of 8, by keropi
I have been using for years large hard drives with my 386/486 builds thanks to OnTrack Disk Manager.
Sure you might lose 2-3kb of memory since it's a "software BIOS addon" but having plenty of space on a machine well worths the loss 😀
As a bonus you also get the ability to boot from CD-Rom, something that those old 386/486 BIOSes don't support.
Might worth looking into if you need more than 512MB of storage space... else a CF is great - quiet and speedy.
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 4 of 8, by Cauterize
Thank you all for the quick replies. I have purchased a 512mb CF card following your advice (£1.99 from eBay), as I wouldn't mind going with the absolute basics for now to get my head round it all.
Davros, thanks for the video link. The guy in the video happens to be a friend of mine called Steve. I had no idea he had the same PC, so I might get in touch with him for further advice.
Regarding the heads and cylinders in the bios, is this something that can be worked out for a storage space of 512mb, or is this not required for a compactflash card? This bit is stumbling me at the moment 🙁
Reply 5 of 8, by 5u3
The values for a 512MB card should be 993 cylinders, 16 heads and 63 sectors.
For setting up/partitioning and format the CF card I'd suggest using the tools from the DOS version you want to run.
As for the needed steps, that depends on a few things:
- Which versions of DOS/Windows do you want to install?
- Do you already have a working operating system on a hard drive, or do you have to install from scratch?
Reply 6 of 8, by Cauterize
Thanks for the values 😀 Most appreciated.
I have MS-DOS 6.22 on floppy disk along with Windows 3.1, hoping to install both from scratch onto the compactflash card.
What I meant more by the formatting/partitioning was, is it possible to do on my laptop using something like DOSBox beforehand, or is it best done in the original hardware?
Reply 7 of 8, by 5u3
Yes, it is possible to set it up on a modern computer, and there are tools to accomplish this, however configuring it in the right way so that DOS 6.22 can work with it in an old machine is not exactly trivial.
Installing from scratch using the original hardware is the safest option in this case.
Also, you have to be careful when moving the CF card with your installed DOS/Win3.1 system to a modern laptop, especially if you intend to write on it.
Reply 8 of 8, by badmojo
I'd love to see some pics of this machine once you get it all up and running - do you have the original monitor so that the megadrive half can work?
