Stretch wrote:I just read about a program called "Sound Blaster Audigy ADVANCED MB" on the Wikipedia article Environmental Audio Extensions. Apparently the software allows you load soundfonts. Does anyone know how the soundfont synth compares to the EMU chipsets present on the AWE/Live/Audigy/Xfi and does it allow you to apply reverb/chorus etc to MIDI playback?
a0divided wrote:I was able to install the purchasable version of MB3 on a Windows 10 laptop, yet it doesn't seem to work properly for me. The "virtual audio device" is installed and seems to work, but the UI keeps telling me that there is no supported audio device available. Does this version *still* only work on specific hardware, and not just any onboard/Realtek HD card? Or is it a problem with Windows 10?
Nucleoprotein wrote:a0divided wrote:I was able to install the purchasable version of MB3 on a Windows 10 laptop, yet it doesn't seem to work properly for me. The "virtual audio device" is installed and seems to work, but the UI keeps telling me that there is no supported audio device available. Does this version *still* only work on specific hardware, and not just any onboard/Realtek HD card? Or is it a problem with Windows 10?
You need to compile GenKGA and generate KGA files, code with fixed password for one of KGA file is here: https://pastebin.com/kRjwNipr
jeckhack wrote:I have following errors like :
error LNK2019: unresolved external symbol _mbedtls_des_init referenced in function "void __cdecl decryptData(unsigned char const *,unsigned char *,unsigned int)" (?decryptData@@YAXPBEPAEI@Z)
1>kRjwNipr.obj : error LNK2019: unresolved external symbol _mbedtls_des_free referenced in function "void __cdecl decryptData(unsigned char const *,unsigned char *,unsigned int)" (?decryptData@@YAXPBEPAEI@Z
PS: Now it seems is available to download and buy from here: http://software.store.creative.com/p/so ... r-x-fi-mb3
EDIT: Code on pastebin have a wrong password for one key, also to install new X-FI MB3 you require to 'fix' setup.inx of main installer (Setup directory) to skip activation (google 'sexy install shield decompiler'). Everything works on my old, integrated AD2000B - this X-Fi MB3 create new, virtual audio device so it should work on ANY audio card! Soundfonts/midi are not supported.
lowenz wrote:It's a DS wrapper with EAX support emulation, not an EAX wrapper :p
Another one: http://kcat.strangesoft.net/dsoal.zip
Users browsing this forum: No registered users and 2 guests
