First post, by ppgrainbow
- Member
I have problem getting the emulated network card with SLiRP instead of PCAP, the NE2000 ISA on the DTK 486 machine (AMD 486DX2 66MHz, 8 MB RAM, Phoenix S3Trio 64 w/1 MB VRAM).
I installed the Arachne v1.97 and tried to configure the IP address to use 10.0.2.15, 10.0.2.2 for the Gateway and 10.0.2.3 for the DNS as well as Boot/DHCP.
When I select Boot/DHCP, Arachne wouldn't even initalise the TCP/IP at all.
Here's a screenshot of the problem that I've been encountering:
The guest OS that i have installed is MS-DOS 5 and Windows 3.11 (no workgroup support).
Is there a way how this can be fixed?
