First post, by realnc
When using a SB16 (or AWE32) with an MT-32, if you play a game that requires the IRQ for MIDI (and SoftMPU,) then you can't get digital sound at the same time because the SB cards share the same IRQ for MIDI and digital sound. Is there any known way/trick to somehow get both?
Reply 1 of 5, by gdjacobs
The MIDI IRQ (when it's required) is 2/9 which is shared with ACPI. SB16 shouldn't use it.
Reply 2 of 5, by realnc
The MT-32 works fine over IRQ 5 (and the game can be configured to use that). That's not the problem here.
Reply 3 of 5, by gdjacobs
Then something is very, very wrong. The PCM IRQ should be 5 or 7.
Reply 4 of 5, by realnc
It is 5. But it's also used for the MPU-401 port (the SB cards don't offer a second IRQ like some other sound cards did, but PCem doesn't emulate these other cards.) So you can't have PCM and IRQ-based MPU-401 at the same time. I'm looking for some sort of workaround for that.
Reply 5 of 5, by gdjacobs
Sounds like you're screwed, maybe. SoftMPU doesn't allow you to alias an IRQ that I'm aware of.
