First post, by cookertron
Hi Vogons,
Does anyone know of a small windows desktop program that can allow me to create a bit of x86 assembly language, run it and see how the registers are effected? It would help if it emulated a bit of memory too.
I have Turbo Debugger but I can't create code on the fly, well not without writing over actually memory.
Thank you
Anthony
Model: Viglen Contender Professional (4SX25) CPU: AMD AM80486DX2-66 Chipset: ALI M1429G (9414) Video: CL-GD5428-80QC-A BIOS: Phoenix DragonBIOS 486 ISA (1993) Sound: Sound Blaster 16 (CT2230)
Reply 1 of 2, by superfury
You can take UniPCemu, put it's debugger in single-step mode, then use nasm to compile a BIOS and copy it to the ROM directory, then run UniPCemu and observe the code executing by pressing numpad 2?
Afaik a compiler that allows for assembly machine code to be changed on the fly doesn't exist yet? I've never seen one at least.
UniPCemu Git repository
UniPCemu for Android, Windows and PSP on itch.io
Older UniPCemu PC/Android/PSP releases
Reply 2 of 2, by danoon
It's not a "small windows" program, but its free. You can use the MSVC community, in a 32-bit program you can inline asm (64-bit doesn't allow inline asm) and see the values for the registers as you step through. I do this a lot in my unit tests to make sure the actual asm on hardware matches what I do in my emulator.
http://www.boxedwine.org/
