First post, by JSO
I can't play it with DOSBOX, what should I do, it never passes to the first screen when I'm typing fifa to run it on dos prompt. Should I make some setting for DOSBOX to be able to run it?
DOS IS THE POWER OF OUR CHILDHOOD MEMORIES!
Reply 1 of 44, by wd
Rank DOSBox Author
DOSBox Author
next dosbox version will run it
Reply 2 of 44, by rcblanke
2008-05-18 15:10 c2woody
* ...better separation of cpu type specific features; make cpu type selectable
Thanks for adding this feature wd, great job!
Reply 3 of 44, by JSO
Thank you!
Reply 4 of 44, by cuttock
Now this is one of the holy grails of DosBox emulation, CPU seletion. Not may games depend on it, but FIFA does. Thanks WD.
Reply 5 of 44, by Neville
A question: does the game work in official CVS versions or we still have to wait for the next release?
Reply 6 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
cvs should work as well
just be sure to make a new configfile and use the prefetch cpu setting
Water flows down the stream
Reply 7 of 44, by Neville
Alright! It works. It needed some tweaking in my particular case. For some reason the included sound setup program (CONFIG.EXE) wouldn't work, so I needed to fiddle with the SB16 default values until they matched the ones stored.
The game *only* works if you manually choose cputype=386_prefetch from the DOSBOX.CONF file, otherwise the game makes DOSBox crash.
This small caveats apart, it works as well as it did on my old 486.
Reply 8 of 44, by rcblanke
FWIW, config.exe works in the windows xp ntvdm.
Reply 9 of 44, by Neville
I'll be damned! It does! I tried under both versions of DOSBox (v0.72 and CVS) and with VDMSound too.
But it never crossed my mind to run it under XP "as is". 😊
Reply 10 of 44, by wd
Rank DOSBox Author
DOSBox Author
Wrong, pentium should work, too.
Reply 11 of 44, by Neville
Didn't try Pentium, I stand corrected. However, what I wanted to emphasize is that the "auto" option wouldn't work with this game.
Reply 12 of 44, by wd
Rank DOSBox Author
DOSBox Author
It's not supposed to work. You can't detect prefetch tricks without slowing down everything to a crawl.
Reply 13 of 44, by Neville
Are there any other games that could benefit from these new options? I'd like to test them as well.
Reply 14 of 44, by wd
Rank DOSBox Author
DOSBox Author
prefetching is useful for a few very old games (fifa is an odd exception but
has been fully analyzed) like one of the Terminator games, and Savage.
The nice thing is that those won't run on any other emulator that i'm aware of.
Reply 15 of 44, by Neville
Ah, OK.
Reply 16 of 44, by njaydg
FIFA 94 does work with both pentium_slow and 386_prefetch settings. Runs just like my old PC did... From FMV intro to actual ingame with voice comments.
The only thing that doesn't work in DOSBox is (as stated above) the config.exe utility.
But I could almost swear it ran just fine with that 'core=prefetch' build that wd released quite some time ago (couldn't find it ATM, though).
Was it supposed to work in the latest builds (tried the 14.08.2008 one) or has something changed and it's not behaving as expected?
Reply 17 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
i recall that config called some non-existing interrupt, but might have been caused by the prefetch stuff as well.
I don't have config.exe anymore. So I pass on this one.
Reply 18 of 44, by rcblanke
Sorry, it didn't/doesn't work for config.exe, unless I'm doing something wrong here.
Reply 19 of 44, by sam767
i still failed to run FIS , i tried original DOSBOx 72 plus CVS files Can i just have a full description again could not find That line CpuType in " Dosbox.inf " file ,
or you guys talkin about physical 386 computer ?
EDITED : btw here's the best music settings that i found on most DOS games
IO 220
IRQ 5 (instead of 7)
DMA 1
HDMA 5
