Phil's Ultimate VGA Benchmark Database Project
Reply 380 of 495, by kithylin
Tertz wrote:
CPU frequencies in "emulators" section may to be higher for CPUs having "boost" like i7 3770. As DOSBox uses only 1 core, then 3770 should work at 3.9 GHz, not 3.4. Real working frequency during test may be checked by cpu-z (as cpu-z slowes down CPU, so fps should be measured without it in memory and frequency checked in the next run).
CPUs in "stock" section should be only at native frequencies, without reduced ones. For example at line 405, I see Pentium III Coppermine E 1000 with 100x7.5. If it's not a mistyping.
Unless owners of new chips disable speedstep and run at 39x on all cores at all times. I helped a friend do this with his I7-2600S and it worked fine and great.
Reply 381 of 495, by BSA Starfire
Added results for Compaq Persario 2232 Cyrix MediaGX 166mhz & Escom Pentium 100mhz with it's original Trident 9440 pci card.
Reply 382 of 495, by PhilsComputerLab
Thank you! First entry with that processor 😀
Reply 383 of 495, by BSA Starfire
Your welcome, this is fun 😀 should have results for IDT Winchip C6 200mhz too next week when my new AT case and psu arrives, best add that to the CPU choices too Phil! I also have VIA C3 & C7D machines I can try too if interested?
Reply 384 of 495, by PhilsComputerLab
Sure, the more results the better 😀
Reply 385 of 495, by easy_john
I've previously added a lot of benchmarks from "La Forge", member of phantom.sannata.ru, for stock and overclocked x5-133 and podp83. Can you please sort tables?
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 386 of 495, by PhilsComputerLab
Yea sure.
Added a few more lines at the bottom 😀
Reply 387 of 495, by RacoonRider
Could you also remove the first line? It's kind of empty 😀
I think it appears when someone starts an entry and then decides against it, then you sort it and get the mess 😀.
Reply 388 of 495, by PhilsComputerLab
Done
Reply 389 of 495, by GeorgeMan
Rows 526 and 527 have a "-" and they are locked. If this was not intended, please fix it. 😀
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 390 of 495, by PhilsComputerLab
Ok you guys are messing with me 😀
I'll check it out next month.
Reply 391 of 495, by GeorgeMan
Why that reaction?
I just wanted to add a couple of entries and couldn't remove the "-"s there. 🙁
Reply 392 of 495, by RacoonRider
GeorgeMan wrote:
Why that reaction?
Phil wanted to close the database half a year ago due to having different priorities. It's still online and still welcomes submissions, so let's be grateful for that.
I actually asked him if he needed help taking care of the database back then, to which he declined. I perfectly understand that, I would not want strangers messing with my work either.
Reply 393 of 495, by BSA Starfire
I know you don't really want to mess with this any more, but it's of a lot of interest still to a lot of us, you have had another 50 entries since the last sort. Any chance you can sort again?
Thanks and sorry to be a hassle,
Chris
Reply 394 of 495, by awgamer
Added results(you just start entering data in google docs and it sticks?) for my 3570k @ 4Ghz DDR3 @ 2000 using HD4k iGPU, running DOSBox 0.74.
3db2   pcpb  doom  tick  quake   sum
528.0 306 238 313 159.1 ?
I don't know how the average is being calculated. in this thread a comment that it's explained in "notes" but I didn't see any.
Reply 395 of 495, by PhilsComputerLab
Chris
Will do!
awgamer wrote:
Added results(you just start entering data in google docs and it sticks?) for my 3570k @ 4Ghz DDR3 @ 2000 using HD4k iGPU, runni […]
What average?
Reply 396 of 495, by awgamer
The AVG FPS column, on the emulators tab.
Reply 397 of 495, by PhilsComputerLab
Ah, ok, I changed it to Sum of FPS like on the other sheets. Because some results are not valid, there is an error.
Yes. Any change is saved in the cloud straight away.
Reply 398 of 495, by awgamer
Added results for virtualbox /w my system.
3db2   pcpb  doom   ticks quake
587.2 2162.3 8.99 8309 814.1 vb 5.0.0 r101573
Reply 399 of 495, by awgamer
Added results for Qemu 2.4.0 /w my system.
715.3 447.5 52.09 1434 74.4 qemu i386.exe
The only other Qemu result is from version 1.7.0, 2.4.0 has vastly improved, quake runs now and doom is a respectable 52 fps instead of single digit, while virtualbox doesn't look to have improved the code that affects doom since grabbing it from qemu. The x64 exe is slightly slower.
