First post, by Chadti99
Any tips to prevent this? It seems to run for a couple minutes then crashes back to windows. I’ve tried disabling the screensaver under the shortcut settings just in case. Any suggestions other than configuring for MS-DOS mode? Assuming I can edit some of the shortcut properties to resolve.
Reply 2 of 10, by Gmlb256
Duke Nukem 3D crashing? How do you have the game configured?
Never needed to use eDuke32 on Windows 9x btw.
Reply 3 of 10, by Chadti99
Gmlb256 wrote on 2021-09-20, 00:51:
Screen mode set to vesa 800x600
Audio set to Sound Blaster
Reply 5 of 10, by Gmlb256
Chadti99 wrote on 2021-09-20, 01:01:
Ok. Which sound card are you exactly using?
I know that at least on SB Live! cards it causes crashing and Ken Silverman has a patch for it on his website. Look for "Duke Nukem 3D "echo" crash patch".
Reply 6 of 10, by Chadti99
Gmlb256 wrote on 2021-09-20, 01:03:
Aha! I’m using a SB Live on this rig! Thank you, I’ll check this out.
Reply 7 of 10, by Chadti99
Just wanted to confirm the patch seems have resolved the issue, thanks again!
Reply 8 of 10, by Gmlb256
You're welcome!
Reply 9 of 10, by Downer
DosFreak wrote on 2021-09-20, 00:38:
If you insist on playing Duke3D in Windows 9x then use eduke32 for Win95
eDuke32 for Win95
Does this not support Voodoo cards? It keeps saying "Unsupported OpenGL driver Detected. GL Modes will be unavailable" for me
Reply 10 of 10, by leileilol
try starting with -forcegl
Debian's fucked
