Reply 20 of 194, by Gmlb256
Akuma wrote on 2021-09-24, 15:22:
That's easier said then done. The symbols/overlay must be stripped first and the header must be patched to reflect the new size., then LZEXE is possible.
I think that he knows that the debug symbols must be stripped prior for release with Borland C++ and the new release of wolfdosmpu already has a smaller EXE size. I have also done this prior without any problems when I was tinkering with the Wolf3D source code years ago.
Reply 21 of 194, by Akuma
First things first: 'I think it does not really matter'
I enjoy the hell out of it 😀
But if you want to go down that road, you might as well do it right.
It is still 42k too big in its unpacked form and in order to mimic the original release well:
  1. search for the 'COMPAQ' string
  2. search for 0x5 0x00 0x00
  3. everything after that can be stripped.
  4. update the exe-header to reflect new size
  5. then compress with LZEXE v1.00 and not the v0.91
LzExe v1.00a [1991] SPEAR.EXE     112835   1993-01-05
LzExe v0.91 [1990] SPEARCM.EXE 114812 2021-09-24
The new one will be even smaller ~500 bytes
LzExe v1.00a [1991] SPEARCM.EXE   114268   2021-09-24
EDIT:
Small note, my savegames dont work after updating (don't know if it was mentioned)
Reply 22 of 194, by Gmlb256
Akuma wrote on 2021-09-24, 18:13:
First things first: 'I think it does not really matter' I enjoy the hell out of it :) […]
Clever EXE compression trick! 😀 To be fair I didn't mention the version of LZEXE.
Not even the recreated Wolf3D versions by NY00123 do this.
Reply 23 of 194, by ericvids
Hi, I have just read about this, actually. But since you mentioned "doing it right"... I actually ended up reading posts in another forum where they attempt to recreate the original .EXE files, and they discovered that there is an option within Borland C++ itself to remove the debugging information. This prevents the overlay from being generated at all. I'm gonna integrate it into my next release. (As for LZEXE version, I might stick to 0.91e as that's the official one that the author, Fabrice Bellard, offers on his website.)
But having said that, and with your mention that save games from previous versions do NOT work (*gasp*! I never actually saved any of my games, so I never knew...), I'm clearly descending into a giant rabbit hole, deciding what is necessary in this hack or not. When I decided on adding LZEXE, I assumed that the goal was simply practical -- to make it possible to transport the .EXE via floppies.
For now I'm tempted to just change the savegame filename to prevent people from reusing their saves across versions. I currently don't know what the consensus is about savegame binary formats -- should I even attempt being compatible with vanilla for this (I feel like I should), or do other mod authors generally ignore this? Also, it's pretty strange why it's not loading correctly -- apparently the variables I've introduced into the data segment to track MIDI state actually mess up the memory structure everywhere else (when they really shouldn't)... I have to look into this more.
EDIT: Actually it's something else... the mere fact that I output a version string on game exit SOMEHOW messes the data segment. I removed it and suddenly savegames from vanilla work fine. What the effin' heck.
Reply 24 of 194, by Gmlb256
ericvids wrote on 2021-09-24, 20:18:
AFAIK most mod authors at the time when "modding" the DOS version were only messing with data structures such as gamestate that are located in WL_DEF.H, which affect compatibility with savegame files. In this case you should be compatible with vanilla.
Sticking with the original LZEXE after stripping the debug symbols with the compiler should be good enough, you don't need to use that trick Akuma showed.
Reply 25 of 194, by Akuma
Gmlb256 wrote on 2021-09-24, 19:55:
I know it was just an observation 😉
Even better 😀
(however its not Fabrice Bellard that chose the compression tool version, it was John Carmack)
Its in development, better to find these sooner than later 😁
I saw there's about a 2k difference, is it possible to put the code into a TSR? Then you would not have to touch the executables at all. Just run the 'mytsr.com' and then the main program wolf3d.exe or spear.exe.
Reply 26 of 194, by Gmlb256
Akuma wrote on 2021-09-25, 12:14:
Speaking of putting code into a TSR, there is one that implements hardware mixing for the GUS called UltraWolf but that doesn't work on version 1.4 and requires patching the original executables. 😁
The music are completely different and the digitized sound are played without proper resampling though.
Reply 27 of 194, by ericvids
Funny you guys should mention putting the code in a TSR -- I actually designed my protocol with that in mind, because I also wanted to support IMF games like Keen 4-6 and Duke Nukem II. 😀 I've been specifically placing my code where I can easily understand their disassembly, so I can replace key functions with interrupt calls to a TSR if need be. The only problem there is that I'm a beginner at this low-level stuff, and the more I thought of doing it like that, the more I just want to "get it over with", which is why I ended up with a plain source mod. 😀
Of course, I don't mind it if someone else takes the current work and writes a TSR version. I'm just happy enough to get it working as it is now.
Anyway, I just made a new release. I now completely reuse existing (unused) state variables, making the data segment as pristine as possible. As a result, the savegame issue is fixed for the Activision releases. (I hope -- I don't have a nice batch of savegames with possible special cases.)
I also made a very small change to the data sending poll routine -- maybe that will make the AWEUTIL TSR cooperate with it now?
Reply 28 of 194, by Gmlb256
ericvids wrote on 2021-09-25, 14:42:
Nice that you got the WOLF3DCM.EXE size very close to the original 1.4 Activision version, it's 99 bytes less. 😀
Sadly AWEUTIL TSR still freezes the computer just after pressing a key during the signon screen. 🙁
Reply 29 of 194, by ericvids
Gmlb256 wrote on 2021-09-25, 15:40:
I have an inkling to what the problem is, but can you try this one? (See attached file.) Also try running it using permutations of the NOXMS and NOEMS options. Let me know the exact behavior.
If nothing still works, I might have to chalk it up to AWEUTIL being, well, an awful util...
Reply 30 of 194, by Gmlb256
ericvids wrote on 2021-09-25, 21:57:
Downloaded attached file, wolfdosmpu finally works with AWEUTIL (nice pun considering the compatibility btw). Thanks for the effort! 😀
However it ocasionally freezes the computer without using the parameters so far.
Reply 31 of 194, by ericvids
Gmlb256 wrote on 2021-09-25, 22:23:
If it doesn't freeze at all when using a certain combination of those NOXXX parameters, I think I'll consider it "good enough" and just warn people with AWE cards to use those switches. Since you did mention that AWEUTIL dislikes programs that use protected mode and XMS, I don't think there's anything I can do to fix it, short of rewriting id's memory manager (which I heard Carmack wrote because he famously distrusted the compiler). 😜
It does have a bad implication on a possible TSR implementation -- that just might be an inferior solution after all, given that I have to wrangle with AWEUTIL for first dibs on NMIs. Just thinking about it gives me a headache.
Reply 32 of 194, by Gmlb256
ericvids wrote on 2021-09-25, 22:41:
Did further testing and with NOXMS only (which I didn't test prior) and expanded memory manager loaded, and works much better.
Reply 33 of 194, by ericvids
Gmlb256 wrote on 2021-09-26, 03:02:
Ah, is that regular EMM386 that comes with DOS? If so, good to know!
If no further issues arise in about a week, I'll remove the ominous BETA word from the release (not that it really makes any difference 😉 )
UPDATE: I found another issue -- the Read This feature on shareware/registered versions (and occasionally on the commercial version, after beating an episode) would always shrink the view window. Fixed in 1.22
Reply 34 of 194, by ericvids
Ok, I discovered a real problem with savegames, and I wonder if anyone here can help me with it:
I initially thought that the Spear of Destiny savegames are already compatible (the games were loading and saving fine), but upon further inspection, I noticed that all of the static objects (treasures, barrels, etc.) are all gone.
Frustrated, I finally tried to build a SPEAR.EXE from https://bitbucket.org/gamesrc-ver-recreation/ … f3d/src/master/, and found that one of my variables is getting placed in the wrong section of the data segment. In particular, the _ylookup table is being relocated in a different portion of the .EXE.
In the original:
 3A81:99B5       _fontnumber
3A81:99B7 _fontcolor
3A81:99B8 _ylookup
3A81:9B48 _displayofs
3A81:9B4A _ca_levelbit
3A81:EC0D _fastpalette
3A81:EC0F _bordercolor
3A81:EC11 _linewidth
3A81:EC13 _pelpan
3A81:EC15 _bufferheight
3A81:EC17 _bufferwidth
In my .EXE:
 3A77:99B5       _fontnumber
3A77:99B7 _fontcolor
3A77:99B8 _displayofs
3A77:99BA _ca_levelbit
3A77:EA7D _fastpalette
3A77:EA7F _bordercolor
3A77:EA81 _ylookup
3A77:EC11 _linewidth
3A77:EC13 _pelpan
3A77:EC15 _bufferheight
3A77:EC17 _bufferwidth
The only way I can ensure that savegames are compatible is if the data segment (3A81 in the original, 3A77 in mine) is generated exactly the same. The reason is that id's crappy algorithm actually saves raw pointers (e.g., for its object linked list) and expect them to just work.
I have no idea how to force a variable to be placed elsewhere in the memory map on Borland C++ 3.1. Is anyone familiar with this issue?
Given this problem, I think I'm going to have to give up on savegame compatibility if no one knows of a solution. 🙁
Reply 35 of 194, by Gmlb256
Some bad news, I'm no longer able to use the recent versions of wolfdosmpu. It freezes right after pressing any key on the signon screen when displaying "Working...".
Only version 1.00 and 1.10 currently works for me on DOS. 🙁
Reply 36 of 194, by ericvids
Gmlb256 wrote on 2021-09-28, 02:28:
Yikes, I may have had a regression at some point.
Can you try this executable? If you can check on both your real MPU401 and on AWEUTIL, that would be great...
Reply 37 of 194, by Gmlb256
ericvids wrote on 2021-09-28, 02:43:
I tested the EXE that you posted, however it only works with the real MPU-401 after a long initialization and it isn't guaranteed.
Reply 38 of 194, by ericvids
Okay, that's really strange... how long is the delay? Also, what do you mean by it "isn't guaranteed", does the program just hang or does it continue without MIDI playing?
How about this one? Is the delay still there? And does it not work with AWEUTIL anymore with NOXMS? (I thought I fixed a bug...)
Reply 39 of 194, by Gmlb256
ericvids wrote on 2021-09-28, 03:13:
The delay is no longer there (it was about 2-4 seconds), but the initialization issue still persist and could not get AWEUTIL working with this anymore no matter which parameter. 🙁
Seems that it's related to the MPU-401 wait loops.
