First post, by twiz11
Would Java be its own category of emulation since its platform-independent and had at one point have its own OS called JavaOS?
iami
RETIRED
This user is no longer active on VOGONS.
Reply 1 of 11, by BitWrangler
It's a virtual machine, like DOSbox is, even though DOSbox is an emulator, but you don't emulate DOSbox on another system, you port or implement it. I guess the Java Virtual Machine is kind of an emulator in that it emulates a machine to run Java on. So it exists as self parody, QED Java is Rodney Dangerfield.
Reply 2 of 11, by twiz11
BitWrangler wrote on 2021-09-30, 01:20:
I've never tried emulating dosbox on another system, its not worth it it seems, also emulating java would be cool if we could turn our pcs into hardcore Minecraft mining rigs
iami
RETIRED
Reply 3 of 11, by Jo22
twiz11 wrote on 2021-09-30, 01:23:
Is it possible to run Win32 DOSBox inside DOSBox using HX Extender?
Reply 5 of 11, by xcomcmdr
twiz11 wrote on 2021-09-30, 01:12:
You don't emulate the JVM, you implement it for a platform.
Can you emulate .NET ? Python ? Ruby ? Lua ? A web browser ?
Reply 6 of 11, by digger
I didn't know about JavaOS, but I'll do you one better: at a certain point Sun (before they were required by Oracle) actually developed chips that could run Java JVM bytecode natively!
I believe they were intended for IoT applications (before the name "IoT" had even caught on).
Maybe JavaOS was intended for exactly those chips? That would make sense.
Reply 7 of 11, by jmarsh
digger wrote on 2021-09-30, 11:31:
ARM chips did the same, for example the J in "ARM926EJ-S" stands for Jazelle which was a special mode the chips featured to natively run Java bytecode.
In reality most of the implementations didn't "run" the bytecode at all but instead had each java opcode trigger a unique exception, where a programmer could place code to perform the java function.
Reply 8 of 11, by digger
jmarsh wrote on 2021-09-30, 11:50:
That doesn't sound very efficient. 😅
Reply 9 of 11, by nightbanshee
So I've been professionally developing Java software for almost 20 years. I think calling it a Virtual Machine is part of the issue. It's not just Java that used that terminology. You can find it embedded in the definition of the .NET common language runtime (CLR), etc. Even virtual machines were used in years prior in mainframes. Unfortunately that term is now overloaded thanks to...well...virtualization technologies. 😉
While the JVM has some similarities with what we normally call VMs (e.g. abstraction, memory virtualization, etc.), They're not really the same thing. Modern VMs utilize a hypervisor or some equivalent layer that allows for general computer programs to be executed on top (e.g. DOS, Windows, etc.). To me that is the key differentiator. I think it is better to think of the JVM and CLR as evolutions of what C++ first provided.
Compaq Portable ii - Lucky find
Compaq Prolinea 486 - Long term restoration
Frankenstein Socket 7 166Mhz Pentium MMX - In progress
Random Pentium III
Dell Latitude D830
Mac Powerbook G3 Pismo
Mac Powerbook G4 15
Reply 10 of 11, by digger
nightbanshee wrote on 2021-10-14, 14:12:
You think? C++ doesn't have an intermediate runtime, or a standard garbage collector for that matter. Isn't something like Smalltalk a more obvious ancestor?
In terms of language on the other hand, I would concur.
Reply 11 of 11, by nightbanshee
When I wrote that I had in mind people implementing garbage collectors for their c++ applications back in the day. But yeah Smalltalk definitely need influenced the JVM.
Here’s an interesting paper on Smalltalk’s influence: https://www.labouseur.com/courses/tpl/ ... savona.pdf.
Random Pentium III
Dell Latitude D830
Mac Powerbook G4 15
