First post, by smullyoz
Trying to install this card on a WinXP 32bit machine.
Downloaded SBXF_PCDRV_L11_2_30_0004.exe from creative.
The drivers install fine without errors, prompt for a reboot.
However after reboot nothing changes, device manager still shows unknow audio device.
This is on MSI MS-7641 motherboard with the latest chipset drivers.
Reply 1 of 2, by LSS10999
Try daniel_k's X-Fi Support Pack.
Xtreme Music should be similar to other X-Fis, but be sure your card isn't Xtreme Audio which is a software-based variant that needs a different driver.
Reply 2 of 2, by mastergamma12
If you ever use that card in Vista or Later, I highly recommend the UAA Daniel K drivers.
Also just found out that he's done doing the drivers.
F
