I have one of these: https://texelec.com/product/resound-new-wave-mca/ I have yet to actually test it. 😜 Just too damn busy.
I'm about 95% sure, the model 77's processor cannot be upgraded. The ram ***SHOULD*** be standard 72 pin simms. And should be upgradeable to 64mb (ish) If you do buy from ebay, I would recommend not getting anything marked ECC or RS6000, they are highly likely to NOT work.
But if you are going to use dos/win311 then 16mb is probably enough and 32 should be more than plenty. I dont actually have a model 77 around to test, but IF the processor is removeable then the only possible cpu upgrade might be the Pentium overdrive. But those upgrades are very hit & miss with IBM.
