Chicony CH-498B voltage regulator mod help.
First post, by Hoping
Hi, I've had this board for some time and it came with a 486dx2-66. Now I want to mod the board to use 3.3 volt cpus. After searching over the net I concluded that the needed voltage regulator is a MIC29152 so I've bought a MIC 29302 to be on the safe side if I want to try some overclock. But As I've thought after soldering the voltage regulator and setting the jumpers for 3.45 volts on the cpu socket there are still 5 volts so it seems that the missing resistors near the voltage jumpers are necessary but I can't find a clear enough image of a CH-498B rev 2.0 to know the values of the resistors. I think that the capacitor at C23 is not necessary because on some images I've found it is not present.
So I'm thinking if anyone has the rev 2 board and can take a picture of the zone around the voltage regulator to see the values of R20,R21,R67,R68 and R69.
Thanks.
    1.62 MiB
    1.75 MiB
    1.43 MiB
Reply 2 of 94, by computerguy08
I had to do a similar mod to my Jetway board, which you can find here: http://www.win3x.org/uh19/motherboard/show/5505
In the unofficial manual, I explained my way of modding the board with a voltage regulator, by replacing one of the resistors with a potentiometer, so I could adjust the voltage to my desire.
In your case, the IC's datasheet would help you understand where to install those resistors.
Looking for a motherboard? You can find it in Ultimate Retro: https://www.ultimateretro.net/motherboards/search
Join our Discord server here: https://discord.gg/HWWH7hsk2p
Reply 3 of 94, by Hoping
My board is a REV 1 and only supports 5V, REV 2 boards support 3.3v.
I tried to make the mod but it is not that I have deep knowledge of electronics, and I did not succeed. From what I understood the voltage is taken from the difference between R20 and the other resistors that are selected with the jumpers. It seems simple but I tried two trimmer potentiometers and I was not able to get values higher than 2.5 volts.
So either I don't understand correctly how it works (very likely) or the two MICs I bought were faulty.
Due to frustration, I left the project and continued with other pending things.
In the future when I feel like it, since there is always danger of damaging the motherboard, I will try again, this time with an LT.
Reply 4 of 94, by ViTi95
Just found that my CH 498B is also a Rev 1.0, and yes you're right, I tried one 3.3v and it didn't boot, so it doesn't support any 3.3v~4v cpu. I guess i'll stick with 5v processors, just bought an AMD 486DX2-80 (25220 E6) and it should be powerful enough for most of the games of that era.
Reply 5 of 94, by Hoping
Well, I did something crazy, an Intel 486dx4 100 with a big heat sink and fan at 5v, and since it was already overvolted, why not setting an 40mhz fsb, and well its wonking, stable and cold.
This madness was due to the fact that I read that intel cpus tolerated 5v and that some member of the forum was using a 3.3v cpu at 5v for years without realizing it.
Reply 6 of 94, by Robin4
Did you already found your solution for this?
I do have a Rev 2.0 with these resistors installed. I can make a picture tomorrow if you want.. But will post the picture to help others out as well.
There seems to also be yellow small capacitors inside the cpu socket.
Reply 7 of 94, by Deksor
Too bad I didn't see this post before, I have this exact same board (here http://www.win3x.org/uh19/motherboards/7821)
Though I got mine this year, it wouldn't have been possible back in 2020.
In the meantime, could you please dump your bios ? There seem to be many revisions and mine isn't the latest one apparently.
Trying to identify old hardware ? Visit Ultimate Retro - Project's thread The Ultimate Retro project - a stason.org/TH99 alternative
Reply 8 of 94, by Hoping
I have to look for that computer in the heap, I'm sure it's there. I left it after testing the stability at 40Mhz and 5v. I did not want to risk damaging anything more since without realizing it had been running at 5v for some time. As I already said, my level of electronics does not go beyond replicating a circuit following a diagram and its instructions, but in case of having a clear photo of the resistors and the voltage regulator, the only problem would be to find the components.
As for the BIOS, what utility should I use to read it?
Reply 9 of 94, by Deksor
Use this utility to dump your bios : http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP
As for the picture, check the link I put previously, there's a clean photo 😀 (if it's not good enough I can make a closer one)
Reply 10 of 94, by Hoping
Here is the BIOS dump.
Bios string 40-E301-001116-00111111-121593-UMC498-H
In the photo I can't read the model of the voltage regulator, maybe the resistors color but no the model of the MIC, thanks.
    ATROM.zip
    55.18 KiB
    8 downloads
Reply 11 of 94, by weedeewee
Deksor wrote on 2021-10-18, 11:19:
I'm gonna suggest taking a closer one, since I can't distinguish the exact colors on the blue resistors that are required 😀
Do not ask Why !
Reply 12 of 94, by Robin4
Here is the bios from my motherboard.
Seems to be version 3.03
40-P303-001116-00101111-072594-UMC498-H
    chicony ch498b.zip
    59.79 KiB
    11 downloads
Reply 13 of 94, by Robin4
Deksor wrote on 2021-10-18, 07:59:
Do you also know whats different the new version from the older one. Did they added support for AMD 586 133 mhz later maybe?
Reply 14 of 94, by Robin4
Hoping wrote on 2021-10-18, 17:45:
Its a MIC 29152BT I guess that one is also used on their CH-471B motherboard.
I think that the resistors are hard to come by..
Reply 15 of 94, by Hoping
The blue resistors are called precision resistors with a tolerance of 2% or less, they aren't common but not hard to find, expensive if you compare it with general purpose resistors. Back then I tried with a trimmer because in the board manual of the ver 2 there are ten pins on the voltage select jumpers but in the ver 1 I have there are only eight so maybe the lower I can set using the resistors of the ver 2 is 3.45v but I don't know the value of the the first resistor used as a reference for the others. So the first steps are, finding the voltage regulator and the value of the resistors,a clear photo of the area would help a lot, back then, since I couldn't find much info about this I used a MIC 29302 that is rated for 3A and I think is similar to the Mic 29152BT rated for 1.5A but not identical.
Reply 16 of 94, by Deksor
Here's a closer photo
Reply 17 of 94, by weedeewee
R20 ? brown red blue black violet ? 126
R21 brown black red orange brown ? 102K
R.. brown red brown silver silver that don's make sense other way round and silver is gray sigh... 881
Wait a minute... there's only place for 5 on OP's board, but deksor's board has six.
silver red green red brown ... gray again 82.5k
brown red green ? white ... can't tell what color that missing one is... looks like lime but ... does not compute 😉 I'm guessing it's gray. and reversed 98.5K
brown green silver orange brown 158k also gray not silver :-p
edit :
violet black blue red brown 70.6K
brown black red orange brown 102k
gray gray brown red brown 88.1K
gray red green red brown 82.5K
white gray yellow green red brown 94.5K
brown green gray orange brown 158K
edit2:
reversed
126
132
12100M <- does not make sense
12K5
12500M <- also does not make sense
13M8 <- also does not make sense
edit : lime = yellow not gray
deksor's board has 5 voltage jumper settings, Op's board only has 4 :-p
Do not ask Why !
Reply 18 of 94, by snufkin
weedeewee wrote on 2021-10-19, 16:57:
looks like lime
Yellow perhaps?
[edit to add...]
dunno if this makes sense, but using the Vout = 1.24*(1+R1/R2) from the datasheet, and using the 158k as R1, that gives (I think)
94.5k = 3.31V
82.5k = 3.61V
88.1k = 3.46V
102k = 3.16V
70.6k = 4.02V
Reply 19 of 94, by weedeewee
snufkin wrote on 2021-10-19, 17:20:
Yellow perhaps? […]
looks like lime
Yellow perhaps?
[edit to add...]
94.5k = 3.31V
82.5k = 3.61V
88.1k = 3.46V
102k = 3.16V
70.6k = 4.02V
Well, yep, then it's yellow not gray.
thanks I was getting hung up on the math.
Do not ask Why !
