First post, by shortcat
As we know texture resolution in old games can be pretty low and bilinear filtering which is used universally can look pretty bad in this situation. High contrast pixels when stretched a lot form this 4-pointed star look - see the attached picture for an example.
So my wish is an ability to replace it with a better algorithm. See this comparison:
Beetle PSX emulator already does this, allowing to use jinc2 algorithm.
    692.07 KiB
Reply 3 of 4, by ZellSF
Texture replacement has been requested a few times, if Dege ever implements that I'm guessing automatic texture replacement will be relatively easy. Maybe possible already using third party tools.
I really want normal2x/3x/4x/5x/6x like GZDoom has for older games. Keeping that pixelated look, without all that pixel crawling.
Reply 4 of 4, by Azarien
shortcat wrote on 2021-10-25, 07:20:
Just remembered one idea - upscaling textures using a "good" algorithm and then using then in the usual render pipeline utilizing bilinear filtering might be practical.
In OpenGL terms, shift all mipmap levels one point "up" and manually upscale level 1 (formerly level 0) into new level 0 using the best algorithm you can find.
That should do the thing while keeping the original texture data intact whenever upscaling is not needed.
