List of motherboards with SB-link (PC/PCI) header
Reply 100 of 153, by ShovelKnight
According to the manual, AOpen AP5TC is a rare Socket 7 motherboard (i430TX) with an SB-Link header.
Reply 101 of 153, by Dant
There appears to be solder pads for SB-Link on the Intel D850EMV2. Its the right configuration of pins and given its proximity to the ICH2, I'm inclined to think its PC/PCI.
The attachment s-l1600.jpg is no longer available
The attachment D850EMV2 PCPCI.PNG is no longer available
Reply 102 of 153, by kolderman
Just did a build with that mobo. Bios update appears through windows only.
Reply 103 of 153, by greasemonkey90s
ShovelKnight wrote on 2020-04-05, 14:42:
I must be special then. Came up on that board in a motherboard lot. Yes your right it indeed does have sb-link. Almost feels kinda useless when it has isa slots already. Either way its a interesting board i hope can work with a 266 Tillamook.
Reply 104 of 153, by TechieDude
2 more boards:
Legend QDI PlatiniX 4 (i850) (PGA423)
Gigabyte GA-6VXE7+ (693A) (PGA370)
Reply 105 of 153, by Joseph_Joestar
I have recently acquired a new retro rig with the Abit ZM6 motherboard and can confirm that it has a working SB-Link header. This motherboard is based on the Intel 440ZX chipset (socket 370).
Just tested it with my Yamaha YMF724 and SB-Link worked perfectly.
My retro stuff
Reply 106 of 153, by Velociraptor
What does the SB-Link do for us?
Reply 107 of 153, by Joseph_Joestar
Velociraptor wrote on 2020-06-27, 17:31:
Connecting a PCI sound card to the motherboard using SB-Link improves its compatibility with DOS games.
Broadly speaking, PCI sound cards use either SB-Link, DDMA or a TSR program to function under DOS. In terms of compatibility, SB-Link tends to give the best results followed closely by DDMA. Compatibility using a TSR program can be hit or miss, varying largely between games.
My retro stuff
Reply 108 of 153, by Velociraptor
Aha! I'd googled it before but hadn't found a nice clear explanation like that. Thanks!
Reply 109 of 153, by zoinknoise
Intel D850GB (their original Pentium 4 board, and the only one they made for Socket 423) has a soldered PC/PCI header.
Reply 110 of 153, by cyclone3d
zoinknoise wrote on 2021-08-18, 00:39:
The variant without the onboard sound has this. Just looked at some pictures.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 111 of 153, by cyberluke
HP Compaq Deskpro EN Desktop PC P1.0GHz SFF (Intel 815E) - on PCI riser there is some Audio connector...might it be SB-LINK? In BIOS there is PCI SERR and PCI bus mastering. IRQ 5 is for onboard audio or used for your PCI sound card. I have ESS 1938S, which runs only in TDMA mode and this causes random hangs and card not being detected. Need something without EMM386 for Carmageddon 3dfx Voodoo 3 😒. In Windows 98 SE it works, but crashes randomly in the middle of some level (game rank 74).
Reply 112 of 153, by Joakim
I am interested in this topic. I have not found much information online about how it actually works. Can you have SB link without any ISA support? (Some boards from this era have unsoldered ISA slots.)
Reply 113 of 153, by Dant
Joakim wrote on 2021-10-23, 15:53:
Yes. The important thing is that the chipset and memory controller supports everything necessary for ISA-style DMA. In fact, I'd say that the sideband signals that are on the PC/PCI connector were more commonly used to support DMA on PCI-to-ISA bridge chips on industrial motherboards. This is why this subject always winds up drifting to late Intel 8xx chipset series boards. Those were the last boards that will ever support ISA DMA and, by extension, PC/PCI.
Reply 114 of 153, by Joakim
As you mention industrial motherboards, was it used for other things than sound cards?
Reply 115 of 153, by Dant
Joakim wrote on 2021-10-23, 18:02:
The actual header and cable weren't, to my knowledge. The sideband signals that PC/PCI uses were also used to connect to PCI-to-ISA bridge chips built onto many industrial motherboards so they could properly support DMA. Most of the ISA cards used with these industrial motherboards were interface cards for various kinds of sensors, or to control a piece of machinery. I vaguely remember that CnC mills and routers and such were stuck with old tech for many years. I don't know of a specific example that needed ISA DMA to work, but I'm sure they existed if this was deemed a necessary feature.
Reply 116 of 153, by Joakim
Maybe I will ask around at work just out of interest. We have some machines from the 80s wher the programs are still run from floppys.. they probably run DOS.
Reply 118 of 153, by Socket3
ABIT BE6-ii has sb-link as well.
Reply 119 of 153, by ynopot
ECS P6IPAT i815 with Tualatin support. I think I'll test it next week with a SV550/Yamaha 724F-V
The attachment IMG_20220710_173244_1.jpg is no longer available
