First post, by Enderman
Hello everyone, for work reasons (don't ask) I was tasked with assembling a Windows 95 PC. After several days I got it working (even with USB support), but the problem is that it needs two serial (RS-232, DB-9) ports, yet it only has one.
We bought a Digitus 2-port serial PCI card (https://www.digitus.info/en/products/computer … cards/ds-33003/), but I can't get it to work, because the oldest supported OS is Windows XP. I have tried other manufacturers' drivers with no luck.
This is no Virtual Machine, it is an actual W95 OSR 2.5 installed from CD-ROM and updated with the latest patches and USB support (plug and play and such).
If everything else fails I guess I could try to use a VM on a modern computer, but I'd like to avoid that if possible.
Do you know of any W95 PCI drivers for serial port cards?
Thanks in advance.
