Tillamook 266MHz and working L2 cache?
Reply 360 of 517, by LeFlash
feipoa wrote on 2021-10-22, 11:40:
What was the result with running dual Tillamooks? I recall reading somewhere that Intel removed SMP on the Tillamooks entirely, not just disabled it. Probably to reduce the transistor count. I tried dual Tillamooks on a socket 5 system using Evergreen and Kingston adapters, but it will only ever see one CPU. If I use the regular P233MMX chips, the system detects both.
At least the corresponding pins are N/C or otherwise used according to the datasheet.
It explicitly mentions the missing SMP.
https://www.versalogic.com/wp-content/themes/ … f/tillamook.pdf
Page 14:
Differences from Desktop Processors The following features have been eliminated in the low-power embedded Pentium processor with […]
MMX technology: Upgrade, Dual Processing (DP), and Master/Checker functional redundancy.
Table 1 lists the corresponding pins that exist on the Pentium processor with MMX technology but
have been removed on the low-power embedded Pentium processor with MMX technology.
Table 1. Signals Removed from the Low-Power Embedded Pentium® Processor
with MMX™ Technology
Signal Function
ADSC#
Additional Address Status. This signal is mainly used for large or standalone L2
cache memory subsystem support required for high-performance desktop or
server models.
BRDYC#
Additional Burst Ready. This signal is mainly used for large or standalone L2
server models.
CPUTYP CPU Type. This signal is used for dual processing systems.
D/P# Dual/Primary processor identification. This signal is only used for an upgrade
processor.
FRCMC# Functional Redundancy Checking. This signal is only used for error detection via
processor redundancy and requires two Pentium processors (master/checker).
PBGNT# Private Bus Grant. This signal is only used for dual processing systems.
PBREQ# Private Bus Request. This signal is used only for dual processing systems.
PHIT# Private Hit. This signal is only used for dual processing systems.
PHITM# Private Modified Hit. This signal is only used for dual processing systems.
you can never be sure, but why should the datasheet lie in case of the pinout?
Reply 361 of 517, by Sphere478
I don’t have dual tillamooks but once tried one and a regular 233 one in master and vice versa it only ever detected one so yeah, I believe no bueno on dual unfortunately
But…..
There exist rumors of some really old socket 5 boards that used non intel smp tech before intel came out with it being able to run dual k6 with adapters.
That may work with tillamooks
Sphere's PCB projects.
Reply 362 of 517, by Sphere478
I decided to try the tillamook in my iWill p55xb2 motherboard and it didn’t go well until I did ALL of the jumper mods shown in the linked pic. (Except the extended 4x mod, not shown)
I even found a jumper setting that enabled 300mhz without having to do the extended 4x mod.
download/file.php?id=101221&mode=view
Reply 363 of 517, by Anonymous Coward
Enabled 300MHz? Are you just doing 4x75, or did you find a way to get 4.5X?
Reply 364 of 517, by Sphere478
Anonymous Coward wrote on 2021-10-29, 07:36:
4x75 mobo won’t go higher
Reply 365 of 517, by Anonymous Coward
It doesn't matter what multipliers the motherboard supports. You can get around that with a little soldering.
I was just wondering if the Tillamook 266 supports 4.5x (documented or not). There is a Tillamook 300 that does, though not in this package.
Reply 366 of 517, by Nvm1
Anonymous Coward wrote on 2021-10-29, 13:53:
How do you mean not in this package? I do have a 300mhz example on a socket7 adapter and if I am correct did post some pictures of it earlier.
Reply 367 of 517, by Sphere478
Nvm1 wrote on 2021-10-29, 14:14:
You have a golden tiger?
Reply 369 of 517, by Anonymous Coward
Is that a question or a statement?
Reply 370 of 517, by Sphere478
pentiumspeed wrote on 2021-10-30, 02:16:
I could not find any tillamook 266MHz in socket 7 format?
Cheers,
they pop up on ebay from time to time
Reply 373 of 517, by Sphere478
TechieDude wrote on 2021-11-13, 14:03:
Now that you mention it, they don't seem to be as readily available as they used to...
Maybe because of this thread 🤣
Reply 374 of 517, by feipoa
SL2Z4 is the 266 MHz mobile Tillamook. https://www.cpu-world.com/sspec/SL/SL2Z4.html
They used to be a consistent $17 on eBay, then $20, then $24, then *poof*
Reply 376 of 517, by Sphere478
Did any non tillamook intel cpus ever get the 4x multi?
I’m trying to figure out if maybe a pre tillamook mobile may have had it??
I’m trying to figure out how to do better than dual 233 on my dual board that is stuck at 66fsb
I can of course do k63+ but not in dual, so it’s not the same 🙁
Reply 378 of 517, by maxtherabbit
rmay635703 wrote on 2022-01-07, 20:36:
Oh how naive we were
https://www.anandtech.com/show/53
It is because of this that a Pentium MMX-166 can outperform its 200MHz Classic brother.
🤣 what bullshit, imagine thinking a MMX could compare to the God tier Pentium Pro
Reply 379 of 517, by Doornkaat
maxtherabbit wrote on 2022-01-07, 21:02:
That quote is about the 166MHz Pentium MMX outperforming the 200MHz Pentium non-MMX though.
