First post, by johnyept
I searched the forum but couldn't find a list of essential system files for Windows. I'm not referring to extra programs like FTP, PDF/Image viewers, MP3 players, etc. Instead I mean Microsoft software and some 3rd party software (not KernelEX) essential for ALL old programs and games to install/run without asking for extra files/patches/updates. I found these in my HDD for the Windows versions I'm using in my retro machines, I'm not sure if they're the latest versions or if they're in the correct order or if I added them to the correct Windows version, but I'm sure I'm missing something and it would be nice if someone could chime in with missing software and/or links for better lists than these.
Windows 3.11:
- Internet Explorer 5.01 16-bit
- Windows Media Player 5.2
- Euro Patch (WIN3EURO.EXE, language specific)
- Win32S v1.30c
- Visual Basic Runtimes 16-bit (VBrun100.exe/VBrun200.exe/VBrun300.exe/vb4run.exe)
- WinG 1.0
- Video for Windows 1.1e
- TCP/IP 32 3.11b
Windows 95 OSR2:
- Windows Installer 2.0 (InstMsiA.exe)
- Internet Explorer 5.5 SP2
- Windows Media Player 6.4 or 7.0
- DirectX 8.0a
- Jet 4.0 SP8 (Jet40SP8_9xNT.exe)
- MMC (Microsoft Management Console) 1.2
- Paint.exe patch if using Office 97 (Paint95.exe)
- Comctl32 Redistributables 5.80.2614.3600 (50comupd.exe)
- DCOM95 Redistributables (DC95Inst.EXE)
- Microsoft Libraries Update (SPEU.exe)
- Windows Sockets 2.0 (w95ws2setup.exe)
- Visual Basic Runtimes 32-bit (vb4run.exe/Msvbvm50.exe/vbrun60sp5.exe)
- Euro Patch (w95euro.exe, language specific)
- Java 1.3.1_20
- Adobe Flash Player 7.0.73
Windows 98 SE:
- Internet Explorer 6 SP1
- Windows Media Player 6.4, 7.1 or 9
- DirectX 8.1 (9.0c is supported but if you need it you might as well use XP)
- .Net Framework 2.0
- Visual C++ Redistributables 2005
- Java 1.5.0_22 (also seems to work with 1.6.07 and 6u7?)
- Adobe Flash Player 9.0.280
- QuickTime Alternative 1.5.6
- Real Alternative 1.5.2
Windows NT 4.0:
- install network drivers before any Service Pack
- Unofficial DirectX 5.0 beta (install SP3, then NT4DX5, then SP6a + Rollup, otherwise it breaks DirectPlay)
- Service Pack 6a
- Service Pack 6a Post Security Rollup
- Windows Installer 2.0 (InstMsiW.exe)
- .Net Framework 1.1
- MSXML 3.0 SP7
- Paint.exe patch if using Office 97 (Paintnt.exe)
- Euro Patch (NT4_Euro.exe)
- Java 1.4.1_07
- Adobe Flash Player 7.0.73 (also seems to work with 9.0.47)
Windows 2000:
- Service Pack 4
- Service Pack 4 Update Rollup 1 v2
- Windows Installer 3.1 (WindowsInstaller-KB893803-v2-x86.exe)
- Windows Media Player 7.1
- DirectX 9.0c
- Jet 4.0 SP8 (included in SP4 Update Rollup)
- .Net Framework 2.0 SP1
- MSXML 6.0 SP1
- Visual C++ Redistributables 2005/2008
- Java 6u31
- Adobe Flash Player 10.3.183.5
- QuickTime Alternative 1.9.0
- Real Alternative 2.0.2
Windows XP:
- Service Pack 3 (requires SP1a or SP2 if installing on RTM)
- Internet Explorer 8
- Windows Media Player 9, 10 or 11
- DirectX 9.0c
- Jet 4.0 SP8 (included in SP2)
- .Net Framework 3.5 SP1 / 4.0.3?
- MSXML 6.0 SP1
- Visual C++ Redistributables 2005/2008/2010/2012/2013/2015/2019
- Java 7u9
- Adobe Flash Player 32.0.0.371 (last version without timebomb)
- QuickTime Alternative 3.2.2 ou 4.1.0 Lite
Underlined version numbers are the last officially supported version for the O.S. mentioned in the official page, in forums or by my own testing.
EDIT 2021-10-29 (1): Added WinG, QuickTime Alternative, Real Alternative
EDIT 2021-10-29 (2): Added Video for Windows, TCP/IP 32, plus installation steps for NT4/DX5
RETRO-W98/2K: MSI MS-6309 v1.0, P3 1Ghz, 3x256MB, GF5600 128MB AGP, VD2 PCI, RTL8139D PCI, TB400-2541 PCI, ESS1868F ISA, 160GB IDE
RETRO-WXP/7: ASUS P5KPL-AM EPU, XEON E5450 3Ghz, 2x2GB, GTS 450 1GB PCI-E, 120GB SSD, 1TB sATA
Reply 1 of 20, by leileilol
You forgot QuickTime. A lot of the 90s FMV games need certain installations of Quicktime! Usually version 2.
Have WinG for Win3.1 installed for that odd bunch of 1995 Windows action games that weren't fully committed to the Win95 hype.
Reply 2 of 20, by johnyept
leileilol wrote on 2021-10-29, 10:13:
Yeah, I remember using WinG at some point in time... About QuickTime, I do have it in my HDD, but in form of QuickTime Alternative 1.56 (last version for 98/Me), and QuickTime Alternative 2.9.2 which the folder mentions being for Win2K/XP/2003 but wikipedia says that 1.90 was the last version to support XP. Will these do the job or does it have to be the full Quicktime program? I also have Real Alternative 1.6.0 and 2.0.0, not sure if these are required by any program but i do remember using them for some reason.
Reply 3 of 20, by Disruptor
When you try to get all available updates for Windows 2000 with an offline upgrade tool you may need to install a Microsoft certificate file first.
However, the latest updates may not be essential - so this is off topic.
Reply 4 of 20, by Stretch
For Windows 2000 robocopy, reg.exe, msconfig from WinXP, and psshutdown.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
Reply 5 of 20, by johnyept
Added WinG (required by some Win3.x games/programs), QuickTime Alternative and Real Alternative (codecs).
Disruptor wrote on 2021-10-29, 11:09:
I didn't mention updates because most of them are no longer available, specially in foreign languages. Individual programs however might not be as hard to find. I still have the original links for some of the ones I listed, so later I'll try to add trustworthy working links for the original files.
Stretch wrote on 2021-10-29, 11:41:
Thanks for the input, but I'm only looking for SYSTEM files/software that might be required when installing/running programs/games.
Reply 6 of 20, by Joseph_Joestar
For retro gaming purposes on Win98SE, all you need is the Windows Installer Update and the DirectX version of your choosing. Usually, that would be DX 7.0a unless you're running software which actually requires something higher. Anything else comes down to personal preference.
BTW, Internet Explorer is not "essential" by any stretch of the imagination.
Reply 7 of 20, by Gmlb256
Joseph_Joestar wrote on 2021-10-29, 14:50:
Some programs may require particular DLL files that comes with IE such as SHFOLDER.DLL, ImgBurn is one of these requiring said DLL file. I wouldn't even navigate with that web browser these days though.
Reply 8 of 20, by Joseph_Joestar
Gmlb256 wrote on 2021-10-29, 15:31:
Some programs may require particular libraries that comes with IE such as SHFOLDER.DLL, ImgBurn is one of these requiring said DLL file.
Just to clarify, I'm not advocating the removal of IE from systems where it's installed by default (i.e. Win98SE). But I don't see the point of upgrading it beyond what comes bundled with the OS, if the main focus of the system is to play retro games.
For those who want to use their rig as an actual old-school workstation with MS Office, utility programs for burning CDs, a media player and whatnot, things may differ.
Reply 9 of 20, by Gmlb256
Joseph_Joestar wrote on 2021-10-29, 15:42:
Indeed, there isn't a real reason to upgrade IE especially if the DLL files are already included and the rest of the stuff is entirely optional if the objective is to just play retro games.
Reply 10 of 20, by jheronimus
Looks like you're not aiming at just gaming-specific updates (there's a bunch of programming libraries in your lists), so for Windows 3.11:
- Microsoft TCP/IP 32 3.11b
- Netscape Communicator 3.0 Gold (that's what I use to browse old websites over a Wayback Machine proxy)
- some kind of a 32bit disk driver (depends on the hardware used)
MR BIOS catalog
Unicore catalog
Reply 11 of 20, by johnyept
Exactly my point, I'm listing required software for games AND programs, because using a retro PC just for games is only half the fun (ok slightly more than half), period correct programs are also part of the nostalgia and can turn a retro PC into a useful machine (once again).
jheronimus wrote on 2021-10-29, 17:04:
Looks like you're not aiming at just gaming-specific updates (there's a bunch of programming libraries in your lists), so for Wi […]
The first two are very useful and I've added them to the list, the other two are simply a browser and drivers, probably nothing requires them to install/run.
Reply 12 of 20, by chinny22
Windows 3x
Y2K patch for File Manager (search y2k WINFILE.EXE)
Reply 13 of 20, by Kalle
Windows 3.x
There's also an updated version for the Calculator.
Reply 14 of 20, by johnyept
Thanks for the suggestions. I did include the Euro patch which hasn't anything to do essential system files, nor Y2K patches but heck, why not? 😀
The Y2K patch for the file manager seems to be Q85557 (Wfwy2kup.exe) and the calculator update seems to be Q124345 (Ww1138.exe).
Most of the files are still available through the Wayback Machine if following the links on the hpcfactor guides. Unfortunately most links to other languages are broken and/or lost in time, in my case PT-PT for Win9x/2K and PT-BR for Win3.x/NT3.x/NT4 since they don't exist in PT-PT. Instead of adding individual links for each file to the 1st post, I'll try to get whatever I can from the hpfactor guides plus what was shared here, compile a list of all sources from where I got the files, then upload a pack (or packs) of files to share with the community. Might take a while to gather the files since free time and patience is in very low quantities lately...
Reply 15 of 20, by Warlord
Around 70% of your lists are non essential.
If your game doesn't need those files than they are not essential. If your video card or drivers don't need them they are not essential either.
johnyept wrote on 2021-11-02, 11:48:
The Y2K patch
Also number of times a game asks for this = Never.
Now if we want to talk about files that may make your user experience better at just general pupose operation of a computer than I might consider some of them, but certainly no all of them.
My general approach to what is essential is how many files can I "REMOVE" from a os and it still be functional at playing my games. SO if I remove 60% of the files from the OS and it still works and can play all my games than obviously they were not essential
Reply 16 of 20, by chinny22
Warlord wrote on 2021-11-02, 16:26:
This is my thinking as well. Why bog down windows with software that's unneeded?
Only time I install a dependency is if I'm specifically asked for it. eg Daemon tools on 9x needs the updated windows installer.
None of my 9x boxes need VB, C++, java, etc.
The Y2k patch for file manager is a quality of life patch when sorting files by date, only other update I apply to 3x is the newer TCP stack.
9x only needs Windows installer
2k and above I don't think I install any patches
I do install the final service pack and supported versions of IE, Office, WMP but that's purely personal and fully admit pointless on retro game rigs.
Reply 17 of 20, by maxtherabbit
That's all fine and good if you're only interested in retro gaming. I myself prefer my retro computers to be capable of the full spectrum of retro computing tasks
Reply 18 of 20, by Warlord
I'be done that too somtimes, however I've found that the choice of software needs to be very light weight and non intrusive for my liking. Also some real soul searching needed to lower expectations as to the worth of certain applications and their usability in 2021 and beyond. Like I can install retrozilla and apply all the tweaks but realistically the usability is so low that I've found it not worth it. I suppose one could still get alot of work done with word 97 and email can still be a thing, but am I really doing that not really it's more of a pretend thing and all that does is bog the system down. I more or less use my retro rigs just for games and if I had serious work to do I wouldn't bother with trying to edit images with some antiguated version of photo shop just becasue it feels like its some retro task I should be able to do I rather use a much more powerful system that doesn't take days to render somthing.
Reply 19 of 20, by johnyept
As expected, the posts are starting to go a little off-topic. As I mentioned in the first post and several posts after, the "essential system files" refer to those files that are usually required by some games AND programs . The purpose is to have a Windows setup in a way that I can install any game AND program without searching for some obscure patch, DLL, codec or 3rd party utility required by it.
I'm not interested in the impact they might have on a game, or CPU usage they might use, since I'm not using a slow computer anyway: 550Mhz + 192MB RAM + 120GB HDD is already overkill for Windows 95 and/or NT4. And if you stop to think about it, back in the day you didn't just install Windows 95 + Windows Installer + DirectX + drivers + games: you would probably have installed almost all that was mentioned in the first post, PLUS a bunch of programs for daily use, on a much slower computer, AND you would game on it anyway!
So, can we agree that this topic is not about how the files/programs mentioned in the 1st post impact the performance of the games or Windows itself, but simply how to make life easier when installing a game OR a program? I know that games are the main reason most of us build our retro machines, but for me the programs are also part of the nostalgia, even if I don't use most of them. Y2K and EURO patches are not needed (that I know of) by any game/program, but they just add to the experience. If I just wanted to quench my thirst for retro games, DOSBOX and GOG on Windows 10 would more than suffice.
