First post, by touche112
I have a Socket 3 board (PAT48PR v1.4) with (currently) a 486SX in it. I'm having a LOT of issues getting any HDDs larger than 256MB to even get detected in any form, even in overlay software.
I'm using a VLB I/O board with a Winbond chipset for my ATA controller. Both channels work great with a Seagate 40MB drive I have - I can boot and use it, no problem. The problem comes when I try CF adapters. I have three different adapters from different brands (one of which is Startech). With a 256MB CF card, it's detected in BIOS with the auto-detect utility and I've installed DOS to it, but can't get it to boot. I get an I/O error - not the typical boot disk error or anything. fdisk /mbr didn't help.
So anyway I moved on to a 1GB, 2GB, and 4GB card, and none of them even power on! It's the weirdest thing - the power LED on the adapters don't light up with any card or adapter. I have tested all four cards and all three adapters on a P4 system and they work fine.
Back to the 486, I have a sound card with a true IDE socket, and I get the same behavior there. Is it possible this board just isn't compatible with anything large?
Reply 1 of 9, by Horun
There is a 504MB maximum with many older BIOS up through about 1994 but an Overlay program should work if the BIOS is set proper. The IDE on a sound card will not work for any boot drive.
Reply 2 of 9, by BitWrangler
Are you trying to boot from primary or secondary channel? Booting secondary channel wasn't guaranteed until later 486 era. Best start with trying to boot as only drive on primary. Particularly if you're trying to use it on the same channel as the 40MB, some of those early AT spec drives were a bit "funny" when it came to co-existence with later ATAPI devices. Which might mean you can't use it with later drives which don't have flexibility in their jumper settings to allow for the older stuff. There was a bit of a crossover era where IDE drives could cope with sharing bus with the first gen of AT drives, but later this was dropped.
Reply 3 of 9, by touche112
Thanks for the replies so far. 😀
Lemme elaborate a bit further. When testing with the CF adapters, the 40MB drive is disconnected and I'm using the adapter(s) as a Single/Master. I've tested with both channels and multiple 40pin cables. The sound card's IDE port was used just to see if I could get a disk manager to see anything at all - not to boot from it.
The primary issue is with the larger cards >256MB, the adapters don't have show power or card detect when the PC is powered on. Note that they DO show both and function properly in other machines.
When using the larger cards, setting the BIOS to no disks or to Type 1 for OnTrack, POST hangs and I get a controller failure message after a few minutes.
Here's a video demonstrating the behavior:
https://youtu.be/D4tubLohaA8
And I've attached images of the sound card and the VLB I/O board.
Reply 4 of 9, by Horun
That is a Tekram DC-280E VLB card, they are fairly decent. Here is the archive of the FAQ for it: http://web.archive.org/web/19970606090525/htt … am.com/FAQ.html
My guess is that the BIOS limitation of DOS 504Mb (528Mb) is why any card larger than your 256Mb will not work. Have you tried making the 1Gb CF with only a 500MB "C" partition using your P4 ?
Reply 5 of 9, by touche112
Horun wrote on 2021-11-13, 20:38:
Good call. I'll try that and report back.
Reply 6 of 9, by touche112
No go. Making a smaller partition (100MB or 500MB) did not change anything.
Reply 7 of 9, by turbooo
Do you get the blinking power LED if the adapter isn’t plugged into the interface card?
Wonder if it might be related to this (though curious that it works on your P4, so maybe not): http://support.fccps.cz/download/adv/frr/cf.html
Reply 8 of 9, by mekamayhem
have you used on-track overlay?
Usually its the bios settings that will cause the system to hang .
Reply 9 of 9, by touche112
mekamayhem wrote on 2021-11-14, 07:50:
No overlay software works. If you see the video I posted, the adapters are in an almost constant power cycle-like state when attached.
turbooo wrote on 2021-11-14, 05:33:
No, without an attached interface none of the CF adapters show any indicator LEDs.
