RaiderOfLostVoodoo wrote on 2021-11-16, 17:49:I did some research on overclocking Athlon XP and found out, that AMD started locking the multiplier at some point. Multiple sou […]
I did some research on overclocking Athlon XP and found out, that AMD started locking the multiplier at some point. Multiple sources stated that AMD started locking the multi in week 35 of 2003, but still sold CPUs with an open multi at this point. Starting with week 43, all CPUs had their multi locked.
So I got myself a sample from week 30, to be sure it has an open multi:
AQUCA 0330WPMW
To my surprise I can't change the multi. I did lower the multi to 12 and it doesn't post.
Anyone got an explanation for that?
Might my CPU be a fake?
I've had a few socket A boards and all of them started without issues when I tried to set multiplier on locked CPU.
That's why I think that there might an issue with your motherboard BIOS. I would try few another multipliers - lower and higher than default one. If this won't change anything, then try another BIOS (newer or older one).
And if this won't help... you can always do mobile-mod and use software like WCPUID to change multiplier. It should be possible in range (IIRC) 3 - 24x for desktop CPUs.
P4 3.4E, P4C800-E Dlx, 1 GB, X800 PRO 256 MB, SB Audigy, XP SP2
A1.4, A7V133, 512 MB, R8500LE, FM801, ME
P3 600, AX6BC, 128 MB, GF2 PRO 64 MB, ALS100+, 98SE
K6/266, MS5149, 64 MB, Virge 4 MB, V1 4MB, ESS1868, 95 OSR2
