First post, by Jo22
So what's about it ? I've recently come across an article at os2museum.com
some of us may should have a look at: http://www.os2museum.com/wp/the-ihc-damage/
Long story short: When Win9x acesses an unprotected disk,
it replaces the OEM identifier (such as ‘MSDOS5.0’) in the boot sector with an ‘IHC’ signature.
Harmless isn't it ? Well, for Win9x that doesn't matter.
But if you using your 9x retro rig for file transfer or backups of you XT machine it may matter.
The OEM indentifier is important for recent DOS versions (3.3 onwards) to check,
wether the disk was created with DOS later than 3.1.
If DOS detects an earlier version, it will try to fix the BPB on the fly.
But why ? Early versions (3.1 to 2x) focused more on the media descriptor byte,
and were buggy when writing correct drive geometry in the BIOS Parameter Block.
Details here: http://www.os2museum.com/wp/dos-boot-sector-b … escriptor-byte/
I know my writing is abit messed up. I've got a flu right now and don't feel very well.
Comments welcome.
Reply 1 of 9, by Stiletto
Digging into WaveBlaster connectors: Can A DB-50XG Talk:
http://www.os2museum.com/wp/can-a-db-50xg-talk/
http://www.os2museum.com/wp/deeper-into-wave-blaster/
The Wave Blaster II Does Talk:
http://www.os2museum.com/wp/the-wave-blaster-ii-does-talk/
Any Soundscape VIVO Fans Here:
(partial source code for the Sound Blaster emulation driver used with the Ensoniq Soundscape VIVO boards, SSINIT.COM.)
http://www.os2museum.com/wp/any-soundscape-vivo-fans-here/
Just wanted to say, if you haven't swung by his blog ever, it's really interesting. 😀
do the Fandango!" - Queen
Stiletto
Reply 2 of 9, by Jorpho
My favorite posts are the ones about the weird edge cases that cause old software and its clever tricks to fail in unexpected ways.
So I asked a question there which seems to have gotten lost in the shuffle:
If the Intel ICH5 southbridge was the last to support PC/PCI DMA and therefore the last Intel southbridge on which the DOS SBINIT/SBEINIT/SSINIT works, then what are the last AMD/VIA/NVidia chipsets that are expected to support those DOS drivers?
I'd like to think some miracles might be possible given that the SSINIT.COM source code is apparently available, but that would probably be too much to hope for.
EDIT: Ahh, here's something.
Intel: Saturn, Mercury, Neptune → no problems 430xX, 440xX, 450xX → ISA DMA only within the E segment [E000-EFFF] 43 […]
Intel:
430MX → no ISA DMA
810 → no ISA DMA
815, 820, 845, 850, 855 → no problems
830MP, 840, 860 → untested
FIC VIA (Apollo):
VIA up to VP2/97 → not cacheable, no ISA DMA
VIA VP3, MVP3, MVP4 → not cacheable
VIA Pro, Pro+, P4 → should work
VIA Athlon → no ISA DMA, no PCI Bus Mastering
ALi (Alladin):
ALi III, IV, V → not cacheable
ALi Pro → no feedback yet
ALi MagiK → no ISA DMA, no PCI Bus Mastering
SiS:
SiS → not cacheable, no ISA DMA
SiS P2/P3 → no ISA DMA at E000-EFFF
SiS Athlon → no ISA DMA, no PCI Bus Mastering
AMD:
AMD 750, 760 (Athlon, Duron, Opteron) → no ISA DMA, no PCI Bus Mastering
Reply 3 of 9, by Stiletto
Thought you guys might like this:
OS2Museum.com has been testing his CompactFlash to IDE to SCSI (PCI) chain, and finds that it can be faster than CompactFlash to IDE.
http://www.os2museum.com/wp/cfidescsi-benchmark-update/
(Original article: http://www.os2museum.com/wp/booting-is-hard/ )
Stiletto
Reply 7 of 9, by pentiumspeed
Those are good posts. I like that all gathered in one place so we can look and select one to read on.
Thanks!
Cheers,
Great Northern aka Canada.
Reply 8 of 9, by Joseph_Joestar
I found their article on OPL3 copies very informative:
http://www.os2museum.com/wp/opl3-copies/
Back when I was shopping for my first ISA sound card, it reassured me that getting the ALS100 and the OPTi 82C930 would give me proper sounding FM synth. They were absolutely right, those 1:1 copies sound identical to the real thing.
My retro stuff
Reply 9 of 9, by Stiletto
Too many missed articles to mention here as usual, but I'll point out this article from today:
https://www.os2museum.com/wp/the-secret-history-of-atapi/
Stiletto
