First post, by 2Mourty
I just purchased a Sony Vaio pcg-v505he. It is working wonderfully, but I opened it up to clean it out (blow out the dust etc). I unscrewed the heatsink and instead of dried out thermal paste it had a verrrrrrry dried out thermal pad. I have never seen such a dry cracked thermal pad in my life. Granted it's 22 years old =) It's not even in one piece anymore but 100 little ones.
Can I just apply thermal pasted and hope that there is enough contact? Just leave the dry thermal pad? How much heat do I need to worry about with a p3 450 mobile?
Thank you ahead of time for reading!
Reply 1 of 6, by pentiumspeed
Still works. They are not meant to be wet thermal pad. They are dry.
Get some 0.5mm or 1mm thick thermal pad next time.
Cheers,
Great Northern aka Canada.
Reply 2 of 6, by 2Mourty
Thank you for the quick reply! Good info.
Reply 3 of 6, by BitWrangler
Stuff like that I stick thin copper shims in, pasted both sides of course.
Reply 4 of 6, by 2Mourty
Thank you for the quick responses. Honestly I should have thought of the copper shim. I did the same thing years ago when i exchanged the ati x600 video card in my Precision m70 for a 6800 go. Man that laptop lasted me a long time. If only the chipset had support for dual core cpu's it could have lasted longer.
Reply 5 of 6, by 2Mourty
So with such a low power (15.4 watts) low speed chip, I'm thinking the thermal pad would be fine. Anybody think to the contrary and think that the paste and shim job will make a large difference?
Reply 6 of 6, by cyclone3d
Good thermal pads wil work fine. That being said, I have been unable to find any that actually have good thermal conductivity. copper shim and good themal paste will beat the snot out of thermal pads every time... just have to make sure that something like that won't slip out of place and cause a short.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
