First post, by bakemono
A recent post reminded me of this diagnostic software for Win 3.1 which I used back in the '90s. Doing a web search about it yielded very little info, eg. https://www.bloomberg.com/press-releases/1997 … es-hurricane-98
I have a ZIP file of it from 1999 so I decided to see if I could get it running and post some screen shots for posterity. Turns out, the ZIP file contained the contents of the installation disk, rather than a running copy, and when I ran the SETUP program it demanded a serial number. If I preserved any serial number, I don't know where it is now 22 years later. My first thought was to hack the SETUP.EXE but the lack of tools which support a 16-bit NE file makes it pretty tough. So plan B was to find a way of manually decompressing all the files. They have names like DISCWIN.EX^ and VBRUN300.DL^ but are not using a common type of file compression. They start with the bytes $00 $06, and after confirming with this handy tool: http://mark0.net/onlinetrid.html I determined that they are using the so-called 'TTComp implode' format http://fileformats.archiveteam.org/wiki/TTComp_archive
After decompressing the files I was able to run both DISCWIN and WING16 under Win3.1 and Win95. Trying to run the video benchmark froze Win95 though...
    7.78 KiB
    16.49 KiB
    7.39 KiB
    5.15 KiB
    7.79 KiB
again another retro game on itch: https://90soft90.itch.io/shmup-salad
Reply 1 of 2, by vetz
Nice find and thanks for the screenshots. If the application is rare and it can't be found anywhere else, then you should make sure to properly archive it.
