Reply 40 of 54, by rgart
- Oldbie
I had a crack at the cyrix chip but didnt have much luck. Ill let you know how it goes in the um8810.
I think for now this system is finished!
The only thing that is on my nerves is that the Turbo Switch cable from the case is 3 pin but the motherboard connector is 2 pin so Im unable to get it working - Plugging in just two of the pins takes my PC down to 4mhz which cant be right surely 😀
Thanks for all your help.
Specs are as follows:
TSENG LABS ET4000/W32I VESA 32-BIT 2 MB DRAM
Intel 486DX4-100 Overdrive CPU
KUO SHENG VLB/ISA Motherboard (ASAKI Chipset)
64 MB Fast Page Ram
Unknown VLB Model IO Controller - UMC Chipset
CT1600 Sound Blaster Pro 2
CT1740 Sound Blaster 16 (MT32/SC55 interface)
Maxtor 1.01 GB Hard disk
Seagate Medalist 10GB Hard disk (jumpered to 2.1)
Mitsumi Quad Speed CDROM - FX400E
Generic 3.11 Disk Drive
Generic Serial Mouse
Honeywell Litetouch Keyboard
Microsoft Sidewinder Joystick
Pro Tech 486 Case
Hansol 920P 19inch CRT Monitor
Roland SC-55
Roland MT-32
MS-DOS 6.22
