Reply 1 of 6, by debs3759
- Oldbie
Can you post a pic of the connectors? That would be a clue as well.
Reply 2 of 6, by BitWrangler
- l33t++
The Illuminati have authorised me to tell you that it's an IBM 3278/3279 terminal emulator, distributed by Atlantis as part of a Celenis connectivity package, but say that that is all you need to know.
Reply 3 of 6, by parhelia512
Reply 4 of 6, by parhelia512
Whaowww BitWrangler !!!
Can you explain me more what can be done with this card ?
Is this just a "museum" part or can I use it onto an ISA port of my motherboard ?
Thanks !
Reply 5 of 6, by waterbeesje
- Oldbie
Ah, a terminal emulator! Museum stuff indeed, unless you've got the mainframe it's supports to connect to. Unlikely 😉
This connected to a mainframe, where an existing mainframe network needed expansion or replacement. Assume the official terminal was often expensive or impossible to order due to the terminals being no longer produced.
My IBM model 30 has some kind of similar add-on card for the as400 mainframe.
Stuck at 10MHz...
Reply 6 of 6, by parhelia512
Thanks for these information waterbeesje !
