First post, by nad53
Greetings guys. I'm looking up for a little help if anybody knows about a reliable / suggested software (if ever exists) to play midi files with opl-2 emulation (or AdLib, I don't know the actual difference). Also ideal, but not a requirement that this software could allow to record the audio sample right there to export them as .WAV files.
Till around 2018 I used to play on Winamp player those midi files and for some reason, they heard pretty much the same as they do within DOSBOX to each game but nowadays I have installed the same winamp version I had back then and I'm listening a different instruments version from the same midi files. Not sure if this is caused by a more recent Windows 10 update or some changed midi file(s) from default Windows GM synthesizer ? If anybody know more about this issue with Winamp, I would appreciate info about it as well.
By the way, I'm not looking any special audio chip emulation options, I just want to hear those midi files the same way it does with DEFAULT options for DOS games, but in a player - outside of DOS games.
Thanks if any of you can bring a help.
