the3dfxdude wrote on 2021-12-08, 13:56:
I did play RCTW on my slower K6-3 with GF2 when it came out. It was 30 FPS, with dips. But the high frequency K6-3 CPU versions really weren't available in stores, so what I ended up with then was just barely enough.
Nice! On my K6-2 it was mostly a slideshow. When I switched to the Thunderbird 1.33 GHz, RtCW was the first game that I played (in fact, that game was probably the main reason why I upgraded in the first place). 😀
Now, of course, being a hoarder, I now also own a few K6-3 (non-plus) CPUs and during my testing I've discovered that the K6-3, even though it's clocked lower, is much more powerful than a regular K6-2. In some titles the performance difference is insane (you basically get twice the performance with a K6-3). Not only that, but the whole experience in Windows 98 is also much better - even for basic tasks like installing games, copying files, there is a very noticeable difference (the K6-3 actually comes pretty close to a Pentium 2 in this regard).
kixs wrote on 2021-12-08, 12:07:
Nice 😀 What voltage does the cpu need at 633?
I keep it at 2.2V with a beefy cooler, and it's 100% stable.
At 2.1V it's 99% stable at this frequency, but in some titles there are occasional crashes, particularly in games that use the 3DNow! extensions.
I should mention, though, that this is a "special" chip. In fact, it's the only K6-3+ that I have which is stable at more than 600 MHz (with an out-of-spec FSB). Most of the others are stable only up to 575 MHz (115 x 5), even @ 2.3V (I did not try a higher voltage than that, because even @ 2.3V the CPU gets really hot).
K6-2+ CPUs are much better in this regard: they usually are much better overclockers, at least in my experience.
I haven't played much with SS7 and K6+ CPUs... I've tested FSB speeds a few years ago and if I remember correctly, at least that particular board, wasn't stable above 110Mhz - could be an early revision or some other brand. So everything I test now, it's around 100Mhz FSB - but for testing CPUs it's good enough 😉 Don't know when or if ever I will put together a complete K6+ system for actually playing games on 🤣
I'm somewhat addicted to SS7 and it's still unclear to me why. 😁
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
