Reply 200 of 908, by Mu0n
@rasteri do you get these compatibility warnings under Settings/Control Panel/System/Performance?
1Bit Fever Dreams: https://www.youtube.com/channel/UC9YYXWX1SxBhh1YB-feIPPw
DOS Fever Dreams: https://www.youtube.com/channel/UCIUn0Dp6PM8DBTF-5g0nvcw
Reply 201 of 908, by rasteri
Mu0n wrote on 2021-11-29, 14:46:
Yeah I get the same thing. I never really looked into it too much as I usually copy stuff directly to the SD card from my laptop and basically just use 98SE as a menu system to launch dos games
Reply 202 of 908, by digger
Perhaps the SD controller is exposed to DOS through a BIOS extension without being compatible with an actual IDE controller at the hardware level?
Reply 203 of 908, by Deon
I noticed that a lot of effort had been built into the Vortex DX weecee design, and the forks thereof.
Is/Was there any reason for not using the DX3 in the weecee design, or was it simply a timing /release issue (DX3 released after the weecee design)?
I am asking, since I too have some nostalgia over the 90's gaming era and would like to develop a similar board to the DX weecee for personal use.
Most of my code is based on 90's IBM hardware, therefore keyboard scan set 3 (from ps/2 era) is prominent, since it requires less logic to translate, as well as Adlib FM, SB16 PCM, and VESA VBE 2.0.
Is the DX3's SOM 100% compatible with Adlib OPL2 (and in my case OPL3) and maybe also with GM or XM (midi) and keyboard scan set 3?
I take it that VESA VBE 2.0 became standard after '95.
Has anyone been successful in utilising the dual core functionality on the DX3 in DOS (Watcom dos4gw, Freedos32, or the like)?
I'm particularly interested in splitting my DOS code to have the control logic in one core and the decoding/rendering in another core.
Thank you all.
Reply 204 of 908, by RichB93
The MicroSD route seems to be fraught with issues - I would expect that just bringing the integrated IDE out to a CompactFlash slot would be more compatible and performant, although I do appreciate that CF cards are more expensive and less prevalent now; another solution would be to add a SATA bridge to the IDE connection and use a SATA SSD; small 120GB drives which would be ideal are insanely cheap now, and much faster that MicroSD.
Reply 205 of 908, by sofakng
I agree that I would have preferred a CompactFlash slot/adapter but I would think SD might be OK if you disable the page file (if using Windows), and limit writing, etc.
Anyways, I received my ICOP SOM and my PCBs are almost here so I placed an order from Mouser for the components. Most of it they had in stock (only 2 cases left though!) but I couldn't find a SOT-223-4 3.3v regulator with 1.2A output so I ordered the largest one available (1A). Any idea if that should work OK?
Reply 206 of 908, by rasteri
Sorry I haven't been around much to answer questions, life is super busy.
To be honest SD cards are so cheap and plentiful that I don't really care about them occasionally failing, I have clone images of all the OSs I use and when an SD fails I'll just re-image a new one. I haven't had one fail yet anyway.
What part number is your replacement regulator? It should be an LDO otherwise you might have issues
Reply 207 of 908, by sofakng
It's an LDO. The part number is LMS8117AMP-3.3/NOPB.
Here is the full BOM of parts I've ordered from Mouser: https://www.mouser.com/ProjectManager/Project … ssID=f0ad39a381
Here were the out-of-stock parts:
C15, C16, C38, C39         	    4	GRM31CR61E106KA12L	CAP CER 10UF X7R 1206	10uF
C25, C26 2 1206YC106KAT2A CAP CER 10UF X7R 1206 10uF
FB1, FB2 2 BLM31PG601SN1L FERRITE 1500 mA 1206 FERRITE
R1, R2, R3, R4, R5 5 TNPW06034K70BEEA RES 4.7K 0603 4.7K
R12, R13, R14, R15, R16, R17 6 ERJ-3GEYJ473V RES 47K 0603 47K
R18, R28, R29, R30, R31, R32 6 ERJ-3GEYJ330V RES 33 0603 33
R22, R23, R24, R25 4 ERA8AEB49R9V RES 49.9 1206 49.9
R9 1 CRCW12064K70JNEA RES 4.7K 1206 4.7K
U4 1 LDL1117S33R IC LDO 3.3v LDL1117S33R
Replacement parts:
CC1206KKX5R8BB106 (C15, C16, C38, C39)
C1206C106K4RACTM (C25, C26)
BLM31PG601SH1L (FB1, FB2)
AT0603BRD074K7L (R1, R2, R3, R4, R5)
RCG060347K0JNEA (R12, R13, R14, R15, R16, R17)
CRCW060333R0JNEA (R18, R28, R29, R30, R31, R32)
RP73PF1J49R9BTDF (R22, R23, R24, R25)
ERJ-8GEYJ472V (R9)
LMS8117AMP-3.3/NOPB (U4)
Hopefully these are the correct/compatible replacement parts. 😀
Reply 208 of 908, by rasteri
sofakng wrote on 2021-12-13, 19:41:
Technically the ESR of C35 is outside the spec of that LDO, but it'll probably be fine. If you have problems with the SD card or ethernet try replacing C35 with a 10uF tantalum capacitor.
Reply 209 of 908, by sofakng
Thanks ... I updated the above post with all of the out-of-stock parts and what I used to replace them. (it's a lot to go through, so I don't expect you to verify everything)
Thanks for the information on the LDO too. Do you see a better replacement on Mouser.com (USA) ? If not, is T491A106K016AT the type of replacement capacitor for C35? This looks to meet the specifications of the input/output bypass capacitors of the LDO?
Reply 211 of 908, by yyzkevin
Are these modules stocked anywhere? Every time this peaks my interest and I start looking I am always faced with request quote, contact for pricing etc. Is that the only way to get the vortex module? (I am in Canada)
www.yyzkevin.com
Reply 212 of 908, by rasteri
yyzkevin wrote on 2021-12-17, 06:01:
Yeah you'll usually have to get a quote from most industrial suppliers. Most of them are happy to sell single quantities to individuals, though.
Reply 213 of 908, by Mu0n
rasteri wrote on 2021-12-17, 11:24:
I got mine by contacting the California based ICOP office by email, getting a quote. I was able to buy 2 at 177 USD apiece + shipping (around 55 USD). I also live in Canada (Quebec). There were no duties.
Reply 214 of 908, by sofakng
I also contacted ICOP but they asked me to through a reseller (WDL Systems) and I paid $183 + $17 shipping. They were extremely helpful and I received it really quickly.
Tomorrow my PCBs arrive so I'll be able to get started with assembly and I'll post pictures and results 😀
Reply 215 of 908, by sofakng
Is R10 supposed to be populated? It's listed as 'NP' but it has a description instead of "DO NOT POPULATE".
EDIT: Can you also verify the VGA connector? I've finished building everything and was ready to solder the VGA connector but the part number in the BOM seems wrong? (ugh!)
The BOM lists K202XHT-E15S-N and the BOM description also specifies a "high density" connector but these aren't through-hole and meant to be soldered on top of the board:
1.27 MiB
1.33 MiB
Reply 216 of 908, by Mu0n
sofakng wrote on 2021-12-20, 21:51:
Only 2 pairs of pads aren't populated. R10 associated with the EEPROM and R19, part of the "pc speaker" signal.
your VGA connector doesn't look like it'll work here.
Here's what I used:
https://www.mouser.ca/ProductDetail/710-618015231121
and ofc, long lead time (sucks about the shortage of many components).
I'm not very good at navigating my way to viable alternatives and even less at editing board design to accomodate other connection strategies.
Reply 217 of 908, by rasteri
Ooops.... that was the BOM that I ordered so I have no idea how I got the wrong part... probably I just have lots of d-sub connectors lying around so I never noticed
Reply 218 of 908, by rasteri
Mu0n wrote on 2021-12-21, 05:38:
Here's what I used:
I think that's a low-density socket, intended for the Joystick connector. I can't actually find a high-density connector on mouser currently
EDIT : found one - https://www.mouser.ca/ProductDetail/EDAC/634- … xYZjEwpUA%3D%3D
Reply 219 of 908, by Mu0n
rasteri wrote on 2021-12-21, 10:19:
Here's what I used:
OOPS was looking at the wrong line in my excel document, this is the one I used, it's slightly cheaper.
https://www.mouser.ca/ProductDetail/649-ICD15S13E4GX00LF
