First post, by Crusader_2005
I just installed DosBox 0.70 on a crappy system ( PII 700MHz, 128MB SDRAM, 8MB video card - Matrox Millenium G200, OS - WIN XP) and tried to run several games. Yesterday it worked fine and the improvements from 0.65 were very obvious(much faster and smoother play) but when I tried to run the program today it crashed. Here's the info about the crash:
Error signature: appname: dosbox.exe, appver: 0.0.0.0, modname: sdl.dll,
modver: 0.0.0.0, offset 002e699
I've included a text file with some information about the error...
Hope it helps in any way. I have to mention that I did not change my system configuration in any way and that all of my drivers were up to date, prior to the first installation of Dosbox 0.70.
I also tried all choices for the "output" option in the config file(and many combinations of all other options that I thought to have some importance for the crash) but the crash still occurs.
As the error report shows it may be something wrong with sdl.dll so if Dosbox 0.70 works for any of you guys, could you please send me both dll files from the program's installation directory? I've tried all that I could think of and it still crashes... Thanks
