First post, by JayAlien
I have a Win98 PC with an AWE64. It's been running great for some time using the default windows drivers.
I installed the AWE64 software suite from CD so I could play around with soundfonts. Now I'm stuck with awful reverb on sounds - for example if I play a game with speech, it's very echo-ey. Playing sounds like Asterisk, Critical Stop, Exclamation from Control Panel/Sound are also like this. The AWE control utility only seems to affect Midi Syth, how do I turn off the reverb (and probably chorus) on the digital playback - it's completely overdone and sounds terrible.
Thanks,
J
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX A4pro 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 1 of 3, by chinny22
From memory...
Open up Volume and hit Advanced under the main control slider
and you see options for Reverb?
Reply 2 of 3, by Gmlb256
It's WaveSynth/WG software that is causing these reverb effects, the best way is to solve this is to remove it (or disable) thru Device Manager. If you want to keep that software then open the Creative Mixer application and you'll see a slider related to reverb on the right side in Wave and MIDI volume sliders.
Reply 3 of 3, by JayAlien
Thanks, I looked at WaveSynth/WG first. The reverb was set to Hall, I set it to None, and then disabled it in Device Manager for good measure. All good now, thanks!
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
