First post, by gemerttower
Hi all!
Busy bringing a Vendex Headstart III back to life. All goes well so far but the videosignal: I'm only getting the screen in monochrome. The message when powering on the system:
Monochrome will be assumed unless there is a co-resident MGA installed.
I have totally no idea what that message is supposed to be. Btw, it's a CL-GD520A ISA card. Using a different card then the output is "full" color; in this case an Oaktech VGA, also ISA, using the same slot.
Card says also 9990-CVGA VER1.1 if that's of any help. Btw, I'm a bit scared of that C in CVGA 😉
Someone who can tell me what this message means, thanks!
