Which USB 2.0 cards for old motherboards
Reply 100 of 397, by zapbuzz
when i initialize insrall of 32gb flash usb2 on usb1 i experience a moment of crawl on the xp desktop with 2 x p3 @1000mhz and i then have to remove, re insert wait 12 seconds for access usb built in so yeah i am not surprised usb1 not very good for 486 but what about under 1gig flash smaller memory map
My VIA based PCI card drops out reading 4gb files. Total dissapointment. Thus I recommend steer away from supposed USB2 white USB port tongue port PCI cards. The VIA USB2 cArds must be USB 1.1 but suppoirt PCI V2.0 marketing mis interpretations? or just scams?
Reply 101 of 397, by zapbuzz
GuillermoXT wrote on 2021-04-06, 18:35:
I am using this one on Win98SE but when i plug a flash drive usb stick the system seems to slow down a bit.
https://www.amazon.de/dp/B001628FXA/ref=cm_sw … ZZTVP11V95WRQ3H
If the stick memory map is massive it will do that it does it to my built in ports and those white tongue USB ports on the card you show say I am a USB2 wannabe.
I have a VIA chipset USB card with whte tongue ports too advertised as usb2 I plugged it into my 2014 pc and done a transfer test between it and my machines built in black tongue USB2 ports ufortunately more like usb 1 speed with legit 32gb USB2 flash memory by Toshiba
Perhaps they are the latest usb 1.1 and they just added the 0.9 as hype?
I think these VIA cards are seriously dependant on the cpu perhaps manual IRQ with mobo ones shut off? I am gettin an NEC maybe it will be both usb2 and less dependant on cpu resources has black tongue USB2 ports so i think i have a green light. if it is too dependant on cpu i'll find another (maybe an intel would be better)
Haven't seen any VIA USB2 PCI cards with Black tonggue USB2 I bet they be nice.
Reply 102 of 397, by zapbuzz
chublord wrote on 2021-07-22, 18:25:
zapbuzz wrote on 2021-07-20, 13:41:
I would probably rely on USB2 for the minimum spec of super socket 7 with an AMD k6 for reliable use.
As far as 486? socket 3??? I'd settle for 100mbit LAN for data transfers, I mean, considering a null modem cable brings the 486 win95 desktop down to a crawl is a great tell tale sign that thing will be nasty with USB1. All USB uses a percentage of cpu to run and thats probably most of the 486 bandwidth. given most up to 44mhz fsb
So lets firewire away 486 doom game machines!
I mostly wanted USB support on my socket 3 system for thumb drive support, so much easier to transfer files that way.
The card I use now works but often locks up the system.
mine locks up but then it unlocks and i remove then insert it works so put it in walk away for say up to 4 hours for really slow pc *or* track down something like 256mb flash memory usb.... and still unplug and plug in again to use 😀
These VIA cards suck balls so next time i got for white tongue USB ports it will be with either Intel or NEC
Reply 103 of 397, by Caluser2000
All the PCI USB cards I've put in my Super Socket 7 K6-2 400 Linux build have worked flawlessly.
Reply 104 of 397, by zapbuzz
Caluser2000 wrote on 2021-07-23, 18:20:
nice but operating systems are like many peoples choice of alcohol: the first ends up the favourite.
Reply 105 of 397, by Caluser2000
zapbuzz wrote on 2021-07-24, 19:10:
ANYONE GOT A DRIVER TO RID THE FREEZER MAN?
Well Linux isn't the first OS I've used-Dr/MS/PC Dos. OS/2, Win98, XP, Win 10(Wifes laptop) and thLinux.
Try something different for a change. You might be surprised.
Reply 106 of 397, by zapbuzz
Caluser2000 wrote on 2021-07-24, 19:18:
Can you please make a thread about it?
asciimiliation detected! anti sudo terminal defences!
Reply 107 of 397, by Kahenraz
I happened to be going through my PCI USB cards today and tested them on a 440BX motherboard with Windows XP. None of the USB 2 VIA controllers worked; one was not detected and the other would cause the system to lock up.
I had very good success with NEC controllers. I did have some lockups when inserting a device at one point but I think that was due to a hardware conflict that I've since resolved. I haven't any issues since.
For fun I also tried a StarTech USB 3.0 PCI card. It did not detect at all. 😀
Reply 108 of 397, by Sphere478
After trying this and that with usb 2.0 and 3.0 cards and for reasons of limited pci slots and the huge issue of the usb 2.0 cards slowing down the system, I’ve come to the surprising conclusion that to heck with them, add a hub to the onboard usb 1.1.
I’ve put these in both of my retro systems, one at first then the other after being so impressed with the first.
Highly recommend them for anyone looking into this topic
Sphere's PCB projects.
Reply 109 of 397, by RobDos
https://www.amazon.ca/gp/product/B000JFJZGG/r … le?ie=UTF8&th=1
Syba SD-VIA-5U 5-Port (4+1) USB 2.0 PCI Card, VIA VT6212 Chip
I'm using this in my P3B-F, it's working great here. I've got a older Socket 3 PC Chips board coming and will test it with that and let you know in a week or two.
P3 Slot 1 - 512MB PC100 - 128GB SSD - RADEON 9200 SE , SB Awe64 ISA - GOTEK MOD
Reply 110 of 397, by lordmogul
In my Socket 370 system (i815 chipset, 98SE/XP dual boot) I'm running a USB 2.0/IDE/SATa combo card with VIA VT6214L and VT6421A chips. No idea which one das what, but so far I had no issues using the USB and IDE ports on it, and drivers for 98 SE are available.
Looks like this (picture from the internet as I can't get the card out right now.)
Not sure about the quality of the card, I got it only to not be limited to USB 1 speeds when moving stuff to the machine, and by now I can just throw stuff over network, but still, not the worst idea.
P3 933EB @1035 (7x148) | CUSL2-C | GF3Ti200 | 256M PC133cl3 @148cl3 | 98SE & XP Pro SP3
X5460 @4.1 (9x456) | P35-DS3R | GTX660Ti | 8G DDR2-800cl5 @912cl6 | XP Pro SP3 & 7 SP1
3570K @4.4 GHz | Z77-D3H | GTX1060 | 16G DDR3-1600cl9 @2133cl12 | 7 SP1
Reply 111 of 397, by octopus
I have this generic USB 2.0 PCI card, which sadly won't work on my FIC PA-2005.
The attachment USB 2.0 VIA is no longer available
Last week my father in law gave me his old pc to tinker with. I was delighted to find another USB 2.0 PCI card inside!
Surely this one from a 2002 pc would work, no?
Well, guess what: it's the exact same VIA chipset from my recently bought one.
19 years in between, what are the odds..
Reply 112 of 397, by weedeewee
Considering there weren't that many usb2 chipsets out there... I'd guess... one in five?
Would be nice to see a photo of the two chips side by side and identify the manufacturing date. 😁
Do not ask Why !
Reply 113 of 397, by RetroGamer4Ever
Yeah, those old VIA chipsets are still on the market. I have no trouble obtaining them, as I have a pile of cards that look just like the one pictured above. They flooded the market during the Windows XP PC blitz, when it became more common to build your own PC or have a shop do it for you, as USB hubs with a few ports cost an arm and leg back then, while the multi-port PCI cards did not. The NEC chips are very hard to find these days and I only have a single unit in my pile of PCI cards, though I keep an eye out for any I come across.
Reply 114 of 397, by weedeewee
RetroGamer4Ever wrote on 2021-12-20, 17:30:
Same for me.
Only one NEC chip which when one looks at the datasheet mentions something about adhering to the preliminary usb2 standard, as if the chip was released before the usb2 standard was finalized.
Do not ask Why !
Reply 115 of 397, by octopus
I found a card with an Opti chip and 2x USB, looks like a fair and simple card. Then I read your comment, looked further and found another with a NEC chipset, 2x USB and 2x firewire... now I'm in doubt!
I'm no scholar in chipsets for USB PCI cards (yet), any advice?
Reply 116 of 397, by weedeewee
octopus wrote on 2021-12-20, 20:38:
is the opti chipset usb card by chance just plain usb1 ? ie max 12Mbit/s.
Do not ask Why !
Reply 117 of 397, by octopus
weedeewee wrote on 2021-12-20, 20:48:
Probably, it's the 82C861 chipset, acording to http://www.opti-inc.com/html/usb1394.html that is a USB 1.1 , 12Mbit/s
The NEC chip is unidentifiable to me...
My main concern is to get it working on my P-2005 main, so I can use a USB mouse instead of searching for a serial mouse. Not sure if USB 1.1 would accomplish that?
Reply 118 of 397, by octopus
weedeewee wrote on 2021-12-20, 17:03:
I like your thought, I'll try to make a side by side tomorrow
Reply 119 of 397, by RetroPC_King
I also have in a box a new, unused USB 2.0 PCI card, with driver, it have a NEC chipset, 4+1 ports. Not tested it yet.
