First post, by tannerstevo
I have tomb raider gold and noticed that there is an S3 patch on the cd. I tried running it using ykhwong's 0.70 cvs dated 20070305 since it has S3 emulation, but all that I got was a message that says S3 virge not detected. Is there any way to make this work? I am curious to see what the graphics look like compared to the 3dfx patch.
Reply 1 of 18, by leileilol
I'm afraid to report that the horrible proprietary s3 3d apis are not emulated yet, probably because of two factors:
- way too few games utilized virge API
- s3 makes horrible 3d cards anyway
Reply 2 of 18, by wd
Rank DOSBox Author
DOSBox Author
0.70 (and much everything before) emulates the s3 as well...
Reply 3 of 18, by gulikoza
not the 3d api 😉
anyway, glide should look better...virge cards were very poor compared to voodoo...
http://www.si-gamer.net/gulikoza
Reply 4 of 18, by wd
Rank DOSBox Author
DOSBox Author
vasyl added more s3 apis?
Reply 6 of 18, by abyss
Isn't dosbox about full support. Dosbox doesn't even support windows 1.x and 2.x and 98 and 95 and it does not support 3d apis. Your still getting beaten by qemu and virtual pc on the early windows games support.
Reply 7 of 18, by DosFreak
No, DosBox is not about "full support". Currently DosBox's goal is to be as compatible with DOS games as humanely possible. Windows 1/2/95/98 are not DOS games. DosBox is not being beaten by anything. If anything the "competition" is being beaten by DosBox. There is no competition since the other emulators do not support DOS games, at least not officially.
Make your games work offline
Reply 8 of 18, by MiniMax
Rank Moderator
Moderator
abyss - For Windows games, you will need WINBox, not DOSBox.
_________________
Reply 9 of 18, by abyss
I tried putting a small cardboard box onto my computer and it didn't fit.🤣
Where can i download winbox.
Reply 10 of 18, by MiniMax
Rank Moderator
Moderator
Nowhere - it does not exist.
_________________
Reply 11 of 18, by wd
Rank DOSBox Author
DOSBox Author
Definitely not. Boot msdos inside dosbox and you even get win1.x to work.
Besides that 2.0-3.11 already work with the builtin dos of dosbox.
Reply 12 of 18, by Wintermute
And even so, today Windows 1.0 and 2.0 are almost useless anyway - especially from the game point of view, which is the main focus of Dosbox.
Reply 13 of 18, by LoneLines
Also, have fun getting games to work on Virtual PC (DOS games), I tried it a few times, the results are less than satisfactory and many games unplayable.
LoneLines list of workarounds for various games in DOSBox:
http://ADogsBox.jellofishi.com
Reply 14 of 18, by `Moe`
www.winehq.org 😉 (which works surprisingly well these days)
Reply 15 of 18, by wd
Rank DOSBox Author
DOSBox Author
Under windows? Doubt it...
Reply 16 of 18, by SysGOD
i agree with you. the S3D API didnt had a chance to become popular, because of the overwhelming success of the voodoo chipset one year later.
it was also not very capable, but it introduces the first hardware 3d render techniques (billinear filtering and perspective correction).
back these days i saw a promotion screenshot of terminal velocity from S3 and i was very impressed, but never had a chance to play this game with its full glory. it would be great if dosbox could emulate the S3D API someday. 😀
EDIT: here is the one and only screenshot i found on the net from the patched terminal velocity which uses the S3D API:
Reply 17 of 18, by leileilol
There's Hellbender, which uses Direct3D (and with obvious Terminal Velocity dervied gameplay and assets)
Reply 18 of 18, by `Moe`
I owned some S3 3D card, bundled with an accelerated version of terminal veolcity, and honestly, it sucked. Performance was good, but tons of geometry errors all over the place, textures not being shown in correct perspective, that kind of stuff. The Voodoo (which I also owned) was deservedly better.
