First post, by Intel486dx33
I wanted to rebuild my first computer which was a “486dx-33 Multimedia custom build”.
Back in 1993. It was built from a small computer component reseller in Silicon Valley.
I chose to have my own custom computer built because computer manufactures did not offer anything
Nice that I wanted at a reasonable price. My computer cost $2500 with a 14-inch SVGA Monitor back in early 1993.
Specs:
CPU - Intel i486dx-33
Motherboard - ISA ( Symphony Chipset )
Memory - 8mb. 4mb FPM RAM
Motherboard Cache - 256kb 128kb.
Video card - Tseng ET4000AX ( 1mb )
Sound Card - Sound Blaster 16 ( CT-1740 )
CDROM - 4x Mitsumi. ( I don’t have a 2x CDROM )
Controller - Gold Star Prime.
Hard Drive - 254mb Conner IDE
Floppy drives - 3.5 and 5.25
Network card - 3com 3c509b
Dial up Modem - 14.4
OS - DOS 5.0 and Win3.11
Reply 1 of 17, by Doornkaat
Did you create and then delete this thread a few days before? I feel like I have already seen it.🤔
Reply 2 of 17, by badmojo
Deja vu is the OP's specialty.
Reply 3 of 17, by Intel486dx33
More Photos:
Reply 4 of 17, by appiah4
Dude, nobody bought or built ISA only 486 PCs in 1993. ESPECIALLY not for multimedia. If you could afford a CD-ROM in 1993 you could afford a VLB.
Reply 5 of 17, by PC-Engineer
I like the idea. An ISA 486 was very common in 1992 and early 1993 if you had the money.
Some remarks to your setup:
- the showed SB16 version is a very late revision, you should stay with CT1730/1740/1750
- the 3Com isn‘t the correct revision too
- the Mitsumi 4x CDROM was released in 1995. The first 4x CDROM where for SCSI interface in early 1994.
- your cache is 128kB only - but it is enough for this setup.
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 6 of 17, by Intel486dx33
appiah4 wrote on 2021-12-23, 12:01:
VLB was mainly a 1993/94 motherboard. But mostly only available to computer builders and NOT used by computer manufactures like
IBM, HP, and Dell until some in 1994 and 1995.
Many computer manufactures were still building and selling ISA motherboards in computers in 1993.
Affordable Multimedia computers for the home computer consumers mostly came out in 1993.
Not well thought out or engineered but computer manufactures just added a sound card and CDROM drive.
Yes, VLB motherboard with 32-bit BUS was better but came along mostly for computer builders and NOT by
Computer Manufactures like IBM or HP or Dell.
To get a VLB motherboard you mostly had to build a computer yourself.
Later with Win95 came PCI motherboards.
So ISA Motherboards were still very popular in 1993.
This is when Multimedia computers first came out and computer manufactures were still trying to figure out
How to build a computer to support the 32-bit BUS to support high data rate transfers that the CDROM required
For best performance of video playback.
Also there may have been a motherboard supply issue for VLB and PCI for computer builders and Manufactures.
Reply 7 of 17, by Intel486dx33
PC-Engineer wrote on 2021-12-23, 13:31:
I like the idea. An ISA 486 was very common in 1992 and early 1993 if you had the money. […]
Thanks for your input.
Yes, I want to be period correct.
1) I have a Sound Blaster 16 CT1770 and CT1740 I will use one of those.
2) 1993 2x CDROM’s are hard to find and many were plagued with cheap capacitors which leaked on the PCB and caused these
CDROM drives to go bad. Thats why there are so few 2x CDROM drives around today.
3) The 3com 3C509b is a 1993 cards.
4) Yes, 128kb of Cache is enough. Actually my old computer from 1993 only had 64kb of onboard Cache.
I thought it was 265kb of onboard cache. I will change these Specs in description.
Reply 8 of 17, by CwF
In '93 or so I had a 'Comtrade' I think it was.
Hint something eisa/vlb 486dx33 8MB.
DTC3292 scsi, 240 Quantum, Pioneer 602 CD changer.
STB vl24? 1-2MB?
It was the last pre-built computer I've purchased.
I used to know what I was doing...
Reply 9 of 17, by Intel486dx33
Some more Photos.
Reply 10 of 17, by H3nrik V!
Otoh, my pre-built dx2/66 came with vlb for graphics and IIRC also multi I/O board. That was 93 or 94. Didn't get CD-ROM or sound until late 95 or early 96 ..
Reply 11 of 17, by Intel486dx33
I am just test fitting everything before I hook everything up in a test bench and try it out.
I found a 1993 Sound Blaster CT1770 and hooked it up. I also have a CT1740 somewhere in boxes but I could not find it.
I have a 4x Toshiba SCSI CDROMs I can try out in this sound blaster card.
I may have to modify the Dallas Battery with a coin adapter.
Does anyone know where I can find a good coin adapter for the Dallas battery ?
My motherboard does not have an optional battery hookup jumpers.
Reply 12 of 17, by Intel486dx33
Well, it works at 33mhz but not 50mhz ?
Reply 13 of 17, by pan069
Intel486dx33 wrote on 2021-12-26, 03:01:
You have a 66Mhz oscillator, so to get 50Mhz on your CPU you have to swap out the oscillator with a 100Mhz oscillator. Then you need to set your jumpers accordingly. From the manual pics you posted, some combo of J12 and J8 it seems.
Reply 14 of 17, by Intel486dx33
Yeah, I think I will keep this build as my original in 1993 which was a 486dx-33
I want to relive the performance differences with high speed 486 CPU’s.
Also I only had 4mb of ram so I want to relive that too and see if I could have fine tuned the settings better
For better DOS game play.
Do you think I will have any “NOT enough memory” issues with DOS games ?
Reply 15 of 17, by pan069
Intel486dx33 wrote on 2021-12-26, 10:34:
Yeah, I think I will keep this build as my original in 1993 which was a 486dx-33 I want to relive the performance differences wi […]
4mb of ram was pretty standard for a 1993 486. It shouldn't give to much issues and will/should be enough for the vast majority of DOS games. E.g. even DOOM can run on 4mb of ram.
Reply 16 of 17, by Intel486dx33
Yes, back in early 1990’s the hardware was expensive so we were educated on how to run the computers with optimal settings
For the OS/programs we were running. Thats the main difference between computers today. Today you really don’t have to
Configure the settings much for optimal performance.
We could do allot with a Pentium 100mhz computer and 32mb ram.
It would run almost everything back in 1997.
Reply 17 of 17, by Intel486dx33
Logo and slogan photos:
