Reply 40 of 47, by BloodyCactus
I just looked on my dosbox, my 475 size com uses 0kb, its using 0x12 paragraphs, so just over 256 bytes..
35.66 KiB
ok I realised what your seeing, the line 136 should be
mov dx,setup_isr ;; already aligned correctly for tsr
shr dx,1
shr dx,1
shr dx,1
shr dx,1
I checked my original, yeah copy pasta error from hacking my uansi driver up for you. if you have umb its fine 😀
Reply 41 of 47, by Peter Swinkels
Okay, I will patch the code once I have access to my own pc and check again. 😀
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 42 of 47, by Peter Swinkels
@bloodycactus:
I added the missing lines, it works as expected now.
Reply 43 of 47, by slartibardfast0
BloodyCactus wrote on 2021-07-27, 22:23:
I just looked on my dosbox, my 475 size com uses 0kb, its using 0x12 paragraphs, so just over 256 bytes.. […]
shr dx,1
shr dx,1
shr dx,1
shr dx,1
hi, sorry for bringing up a nearly old post.
is there a license or a name I could cite for this TSR shell?
I'm in the middle of writing up some ms-dos code for a Timestamp Counter based delay function/frame/tick-timer
and would eventually like to make a TSR/DOS API with for patching older speed sensitive games.
a NASM skel like this is pretty much perfect, cheers
Reply 44 of 47, by BloodyCactus
nah I'm not worry, call it PD 😀 use it as you will, its all cool.
just make sure you get the little patch I put above for fixing the memory
Re: Writing a TSR for memory dumping.
Reply 45 of 47, by Peter Swinkels
@slartibardfast0: license? Nah, just leave a little positive feedback or a link to my project.
Reply 46 of 47, by slartibardfast0
Thanks @BloodyCactus got that patch running. ahh cheers, this is great, will save a lot of time.
@Peter Swinkels I'll be sure to reference your TSR on github when I've something up there too
Reply 47 of 47, by Peter Swinkels
@slartibardfast0: that would be appreciated!
