OGG TO CUE?
First post, by Matt The Soopaa pro
is there any way or software which convert .ogg,.mp3,.wav into a cue file?
Reply 1 of 2, by Falcosoft
Matt The Soopaa pro wrote on 2021-12-27, 23:03:
You cannot 'convert' audio files to cue files since cue files are not audio files at all. Cue files are metadata files in simple text format that describe how the tracks are laid out in binary CD/DVD image files.
So to get cue/bin files you have to use a CD/DVD burning program (CDRWIN was the one that originally started to use cue/bin files) and write your audio files as a disk image. Depending on what kind of image you want to make you can choose either CD Audio or CD/DVD data disc /image type. In case of CD audio image type your compressed ogg/mp3 files will be decompressed to raw wave files.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2 of 2, by Matt The Soopaa pro
ok thanks but where can i install cdrwin
